Support for Somfy Connexoon and Tahoma
- gdisselkoen
I'm waiting for support of Somfy devices via the Somfy Connexoon.
There is very well documented API available that works for both the Connexoon box as the TaHoma box.
A home is a home when it's an automated home.
INendels
- Domoticz version: 2025.1
Re: Support for Somfy Connexoon and Tahoma
Here is a link to a python3 library, but i can't make it to work.
https://github.com/tetienne/somfy-open-api
hope this helps for integration in domoticz.
OedzesG
Domoticz plugin for Tahoma IO products... blinds interieur and exterieur!
https://github.com/nonolk/domoticz_tahoma_blind
INendels
thnx,
installed it and can control my screens, will test it a while because during connecting domoticz crashed a lot.
but i will see if domoticz keep running.
OedzesG
i had the same progblem, after every device that was found i needed to restart my domoticz. (3 times in total)will test it a while because during connecting domoticz crashed a lot
but now it looks verry stable...
nitpicker
- Domoticz version: 2022.2
works this plugin also with the connexoon? because that device is a lot cheaper than the tahoma...OedzesG wrote: Wednesday 22 January 2020 21:45 Domoticz plugin for Tahoma IO products... blinds interieur and exterieur!
Skippiemanz
- Domoticz version: 4.10233
On github it is stated to work with the tahoma and the connexoon. I Will give it a try soon. Thanks for pointing at this Solution.nitpicker wrote:works this plugin also with the connexoon? because that device is a lot cheaper than the tahoma...OedzesG wrote: Wednesday 22 January 2020 21:45 Domoticz plugin for Tahoma IO products... blinds interieur and exterieur!
nitpicker
You have both? The Tahoma and the Connexoon?Skippiemanz wrote: Sunday 02 February 2020 10:26 On github it is stated to work with the tahoma and the connexoon. I Will give it a try soon. Thanks for pointing at this Solution.
Skippiemanz
Nope i only have the connexcoon.
Just tested it out and worked flawlesly no crashes upon adding screens.
thanks!
thanks!
sgsdebruijn
Hi all, try installing the stuff from github, but still no Tahoma in Domoticz by Hardware,
files are in
domoticz\domoticz_tahaoma_blind\
plugin.py
Python3 (3.6.9) installed
If starting the script,
~/domoticz/domoticz_tahoma_blinds$ python3 plugin.py
TRaceback (most recent call last):
File "plugin.py", line 21, in <module>
import Domoticz
ModuleNotFoudnError: No module name "Domoticz"
Who can help me out,
files are in
plugin.py
import Domoticz
sgsdebruijn
made a plugins directory in Domoticz and installed the stuff in that directory.
Still no luck
Still no luck
sgsdebruijn
Problem was the version of Python and Pythonlib, this did the trick,
sudo apt-get install python3.7 libpython3.7 python3.7-dev -y
sudo systemctl restart domoticz.service
vspamn
I keep getting the following error:
I verified my credentials through https://dev.duboc.pro/tools/setup (server: TaHoma / Connexoon). I am using a Connexoon.
Any ideas?
Tahoma auth errorAny ideas?
Hann1BaL
Did this but:sgsdebruijn wrote: Tuesday 31 March 2020 16:43 Problem was the version of Python and Pythonlib, this did the trick,
Once I added the hardware the plugin was crashing regularly.
I found out that it happened when trying to switch multiple devices at once, when grouping devices per room.
So to control the devices I made a Dummy switch Blinds Percentage Inverted
And used that too control a dzvents script, which eiher fully Opens, Closes or set to the level on the dummy switch:
devices = {
1205
execute = function(domoticz, kantoor)
domoticz.log(kantoor.rawData[1])
--domoticz.log(kantoor.state)
if (kantoor.state == 'Closed') then
domoticz.devices(1192).close()
domoticz.devices(1197).close().afterSec(1)
elseif (kantoor.state == 'Open') then
domoticz.devices(1192).open()
domoticz.devices(1197).open().afterSec(1)
domoticz.devices(1192).setLevel(kantoor.rawData[1])
domoticz.devices(1197).setLevel(kantoor.rawData[1]).afterSec(1)
1192 and 1197 are 2 windows in the office room.
The aftersec(1) (and for other rooms with more devices followed by aftersec(2)) makes sure it sends the command a sec later.
Since then it has been very stable.
- madpatrick
- Domoticz version: 2026.1
Hi Guys,
I'm about to buy new screens with a somfy system and just want to be sure.
Can this plugin of Domotiz controll the latest Connexoon IO version (i'm reading all about RTS)
Can you control each screen seperatly ?
Not sure how the screens will appears in Domoticz as a device
Thanks for you feedback!
sgsdebruijn
Yes, possible. 8n Domoticz separate screens like normal RTS
- madpatrick
So Domoticz sends a signal to the Somfy Connexoon box and this will send a signal to the screen ?sgsdebruijn wrote: Friday 18 September 2020 19:22 Yes, possible. 8n Domoticz separate screens like normal RTS
sgsdebruijn
vspamn
Is there a way to let Domoticz control a terrace screen through the Tahoma box? The terrace screen uses a different app, but the same box.
- madpatrick
I'm setup mu Somfy blinds with the Tahoma box and the Plugin into my DomoticzOedzesG wrote: Wednesday 22 January 2020 21:45 Domoticz plugin for Tahoma IO products... blinds interieur and exterieur!
After switching some blind I notices that it restart my Domoticz .
I see the folowing errors in my log :
2021-04-03 19:02:08.733 Status: User: Admin initiated a switch command (493/Somfy - Erker Blok 1/On)
2021-04-03 19:02:08.736 (Dummy Schakelaars) Light/Switch (Somfy - Erker Blok 1)
2021-04-03 19:02:08.790 Status: dzVents: Info: -=# Screens #=-: ------ Start internal script: Screens Erker Blok 1: Device: "Somfy - Erker Blok 1 (Dummy Schakelaars)", Index: 493
2021-04-03 19:02:08.791 Status: dzVents: !Info: -=# Screens #=-: Screen Erker blok 1 Dicht
2021-04-03 19:02:08.791 Status: dzVents: Info: -=# Screens #=-: ------ Finished Screens Erker Blok 1
2021-04-03 19:02:08.822 (Somfy Tahoma) Not connected before processing command, must connect
2021-04-03 19:02:08.823 (Somfy Tahoma) Not connected before processing command, must connect
2021-04-03 19:02:08.960 (Somfy Tahoma) Sending command to tahoma api
2021-04-03 19:02:18.007 Status: User: Admin initiated a switch command (493/Somfy - Erker Blok 1/Off)
2021-04-03 19:02:18.009 (Dummy Schakelaars) Light/Switch (Somfy - Erker Blok 1)
2021-04-03 19:02:18.061 Status: dzVents: Info: -=# Screens #=-: ------ Start internal script: Screens Erker Blok 1: Device: "Somfy - Erker Blok 1 (Dummy Schakelaars)", Index: 493
2021-04-03 19:02:18.062 Status: dzVents: !Info: -=# Screens #=-: Screen Erker blok 1 Open
2021-04-03 19:02:18.063 Status: dzVents: Info: -=# Screens #=-: ------ Finished Screens Erker Blok 1
2021-04-03 19:02:18.081 (Somfy Tahoma) Not connected before processing command, must connect
2021-04-03 19:02:18.218 (Somfy Tahoma) Sending command to tahoma api
2021-04-03 19:02:22.177 (Somfy Tahoma) Updating device:Somfy - Erker_1
2021-04-03 19:02:22.186 (Somfy Tahoma) Updating device:Somfy - Erker_2
2021-04-03 19:02:26.659 Status: User: Admin initiated a switch command (494/Somfy - Erker Blok 2/On)
2021-04-03 19:02:26.662 (Dummy Schakelaars) Light/Switch (Somfy - Erker Blok 2)
2021-04-03 19:02:26.720 Status: dzVents: Info: -=# Screens #=-: ------ Start internal script: Screens Erker Blok 2: Device: "Somfy - Erker Blok 2 (Dummy Schakelaars)", Index: 494
2021-04-03 19:02:26.721 Status: dzVents: !Info: -=# Screens #=-: Screens Erker blok 2 helemaal open
2021-04-03 19:02:26.721 Status: dzVents: Info: -=# Screens #=-: ------ Finished Screens Erker Blok 2
2021-04-03 19:02:26.751 (Somfy Tahoma) Sending command to tahoma api
2021-04-03 19:02:32.267 (Somfy Tahoma) Updating device:Somfy - Erker_1
2021-04-03 19:02:32.277 (Somfy Tahoma) Updating device:Somfy - Erker_1
2021-04-03 19:02:32.284 (Somfy Tahoma) Updating device:Somfy - Erker_2
2021-04-03 19:02:32.290 (Somfy Tahoma) Updating device:Somfy - Erker_2
2021-04-03 19:02:32.296 (Somfy Tahoma) Updating device:Somfy - Erker_2
2021-04-03 19:02:35.918 Status: User: Admin initiated a switch command (494/Somfy - Erker Blok 2/Off)
2021-04-03 19:02:35.920 (Dummy Schakelaars) Light/Switch (Somfy - Erker Blok 2)
2021-04-03 19:02:35.973 Status: dzVents: Info: -=# Screens #=-: ------ Start internal script: Screens Erker Blok 2: Device: "Somfy - Erker Blok 2 (Dummy Schakelaars)", Index: 494
2021-04-03 19:02:35.975 Status: dzVents: !Info: -=# Screens #=-: Screens Erker blok 2 dicht
2021-04-03 19:02:35.975 Status: dzVents: Info: -=# Screens #=-: ------ Finished Screens Erker Blok 2
2021-04-03 19:02:36.012 (Somfy Tahoma) Sending command to tahoma api
2021-04-03 19:02:36.828 (Zwave USB) Light/Switch (PIR Sensor)
2021-04-03 19:02:36.829 Status: OpenZWave: Alarm received (Home Security: Motion Detected at Unknown Location), NodeID: 31 (0x1f)
2021-04-03 19:02:36.833 (Zwave USB) General/Alarm (PIR Alarm Type: Home Security 7 (0x07))
2021-04-03 19:02:36.839 (Zwave USB) Light/Switch (PIR Home Security)
2021-04-03 19:02:36.882 (Zwave USB) Light/Switch (PIR Sensor)
2021-04-03 19:02:38.220 Error: Domoticz(pid:35175, tid:35222('Plugin_ASIO')) received fatal signal 11 (Segmentation fault)
2021-04-03 19:02:38.220 Error: siginfo address=0x12b00008967, address=0x7f423ae454fb
2021-04-03 19:02:38.588 Error: Thread 12 (Thread 0x7f41ff7fe700 (LWP 35222)):
2021-04-03 19:02:38.588 Error: #0 0x00007f423ae451d9 in waitpid () from /lib64/libpthread.so.0
2021-04-03 19:02:38.588 Error: #1 0x000000000067c3c5 in dumpstack_gdb(bool) ()
2021-04-03 19:02:38.588 Error: #2 0x000000000067c96e in signal_handler(int, siginfo_t*, void*) ()
2021-04-03 19:02:38.588 Error: #3 <signal handler called>
2021-04-03 19:02:38.588 Error: #4 0x00007f423ae454fb in raise () from /lib64/libpthread.so.0
2021-04-03 19:02:38.588 Error: #5 <signal handler called>
2021-04-03 19:02:38.588 Error: #6 0x00007f41e4678560 in ?? ()
2021-04-03 19:02:38.588 Error: #7 0x00007f423b72e891 in BIO_write () from /lib64/libcrypto.so.10
2021-04-03 19:02:38.588 Error: #8 0x00000000009bbda6 in boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::executor>, boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>, boost::_bi::bind_t<void, boost::_mfi::mf2<void, Plugins::CPluginTransportTCPSecure, boost::system::error_code const&, unsigned long>, boost::_bi::list3<boost::_bi::value<Plugins::CPluginTransportTCPSecure*>, boost::arg<1> (*)(), boost::arg<2> (*)()> > >::operator()(boost::system::error_code, unsigned long, int) ()
2021-04-03 19:02:38.588 Error: #9 0x00000000009bd28b in boost::asio::detail::reactive_socket_recv_op<boost::asio::mutable_buffers_1, boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::executor>, boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>, boost::_bi::bind_t<void, boost::_mfi::mf2<void, Plugins::CPluginTransportTCPSecure, boost::system::error_code const&, unsigned long>, boost::_bi::list3<boost::_bi::value<Plugins::CPluginTransportTCPSecure*>, boost::arg<1> (*)(), boost::arg<2> (*)()> > >, boost::asio::detail::io_object_executor<boost::asio::executor> >::do_complete(void*, boost::asio::detail::scheduler_operation*, boost::system::error_code const&, unsigned long) ()
2021-04-03 19:02:38.588 Error: #10 0x000000000077f03c in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2021-04-03 19:02:38.588 Error: #11 0x000000000099dc71 in Plugins::BoostWorkers() ()
2021-04-03 19:02:38.588 Error: #12 0x0000000000ae6396 in thread_proxy ()
2021-04-03 19:02:38.588 Error: #13 0x00007f423ae3dea5 in start_thread () from /lib64/libpthread.so.0
2021-04-03 19:02:38.588 Error: #14 0x00007f42394709fd in clone () from /lib64/libc.so.6
2021-04-03 19:03:08.878 Status: Domoticz V2020.2 (c)2012-1970 GizMoCuz
2021-04-03 19:03:08.878 Status: Build Hash: 0, Date: 1970-01-01 01:00:00
Anybody a clue what could be the problem ?
