Make it possible to add devices to a room in the devices list
roblom
Post by roblom »
For now it's only possible to add devices to a certain room in the room plan. The main disadvantage is that it's not possible to add multiple devices at once and also it's not possible to add inactive devices.
It would be nice if you can select multiple devices in the devices overview and then add these selected devices to a room all at once.
mgugu
Re: Make it possible to add devices to a room in the devices list
Post by mgugu »
Should be a nice feature.
psubiaco
Post by psubiaco »
I also believe that's a great feature:
select more than one device that can be added to the roomplan.
In the picture below, I need to select all devices starting with eNiro: and add them a "car" dashboarb within wallbox and car devices.
Paolo
Domoticz version: 2024.7
Alternatively it is now possible in current beta 2024.4 to add a device to a room from the device edit function
Domoticz-add to roomplan.png (26.33 KiB) Viewed 1154 times
averter
Domoticz version: 2024.4
Post by averter »
waltervl wrote: Thursday 04 July 2024 16:24 Alternatively it is now possible in current beta 2024.4 to add a device to a room from the device edit function
This is useful but does not solve the hassle of having to add the devices one by one. +1 on this request. Thanks.
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
Where can I found this in the device edit function.
Greetings McMelloW
See the screenshot in my previous answer......
solarboy
Domoticz version: 2024.6
Post by solarboy »
Would also be nice and "Edit" and "Timers" button next to the "set used/unused" button in the device list. I find it's often easier to use the "devices" page to find a specific device, especially when they are hidden, eg $testdevice. To alter a timer on a hidden device I have to first unhide it and before it appears in switches/utility/scenes etc.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
McMelloW
Post by McMelloW »
waltervl wrote: Wednesday 14 August 2024 14:22 See the screenshot in my previous answer......
There is not such a screen for dummy devices.
Greetings McMelloW
So on other devices when pressing on Edit button you see the roomplan section, but on Dummy devices not? Strange....
I cannot test now but it feels really odd....
habahabahaba
Post by habahabahaba »
I'm on 2024.4 and have no such function at all devices - dummy or real.
It was implemented on beta 2024.4 so released in stable 2024.5
McMelloW
Post by McMelloW »
waltervl wrote: Thursday 15 August 2024 14:16 It was implemented on beta 2024.4 so released in stable 2024.5
My Domoticz runs at 2024.7 (build 16172)
When I click on the edit button, I get the following screen.
With other devices I see the screen you placed above. So not all devices can added to a plan on the way you suggest.
Greetings McMelloW
So looking at the change that a user made https://github.com/domoticz/domoticz/pull/6035 it is only for add/remove device to roomplan in light/switches device edit page. So not on other devices (yet)
