SOLVED: Telegram chatid and api key available to scripts ? Topic is solved
psubiaco
Post by psubiaco »
I'd find very useful for Domoticz to export a global variable within settings to scripts.
I use several LUA scripts, and it will be great if scripts can get a variable table within the Telegram API key and chat_id defines in Setup -> Settings -> Notifications, so it's not needed to duplicate those variables inside external configuration files.
Paolo
Domoticz version: 2026.3
Re: Telegram chatid and api key available to scripts ?
The settings are available with an API call for Lua with curl. See also viewtopic.php?t=35048
psubiaco wrote: Sunday 14 March 2021 16:37 Hi,
With sufficient authorization it's quite easy to get these values from domoticz via the API.
See below dzVents (100% Lua) example
local scriptVar = 'settings'
return
    on =
        timer =
            'every minute'
        httpResponses =
            scriptVar,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
    execute = function(dz, item)
        if item.isTimer then
            dz.openURL({
                url =  dz.settings['Domoticz url'] .. '/json.htm?type=settings',
                callback = scriptVar,
            return
        if item.isHTTPResponse and item.json then
            -- dz.utils.dumpTable(item.json) -- Dumps all values to log
            dz.log('TelegramAPI: '.. item.json.TelegramAPI, dz.LOG_DEBUG )
            dz.log('TelegramCHAT ID: ' ..item.json.TelegramChat, dz.LOG_DEBUG )
            dz.log('There was a problem handling the request', dz.LOG_ERROR)
            dz.log(item, dz.LOG_DEBUG)
psubiaco
Post by psubiaco »
Hi waaren,
thanks a lot for your reply. I didn't know that settings were available in json!
Having a table/dict variable with all settings is easier to access, but json is a good workaround as well.
Paolo
Paolo
psubiaco wrote: Sunday 14 March 2021 18:11 Hi waaren,
Paolo
Have a look at this wiki page to see what else is available via the API in json returns
