I encountered the need to modify from a script or a plugin surveillance camera settings in domoticz.
It seems to me that parameters are not exposed.
Would it be possible to do it in one of the next release?
The scenario i am using it , is where the camera after reboot changes its listening port, so having this updatable would be great.
Thank you
Camera surveillance parameters exposed on JSON interface Topic is solved
- Target OS: -
- waaren
Re: Camera surveillance parameters exposed on JSON interface
Is this what you are looking for ? (image url is base64 encoded)FrancescoS wrote: ↑Friday 10 April 2020 10:53 I encountered the need to modify from a script or a plugin surveillance camera settings in domoticz.
http://<domoticzIP:domoticzPort>/json.htm?type=cameras
http://<domoticzIP:domoticzPort>/json.htm?type=command¶m=addcamera&address=192.168.192.111&port=19765&name=test&enabled=true&imageurl=aW1hZ2UuanBn&protocol=0
http://<domoticzIP:domoticzPort>/json.htm?type=command¶m=updatecamera&address=192.168.192.111&port=19767&name=test&enabled=true&idx=1&imageurl=aW1hZ2UuanBn&protocol=0
- Target OS: -
yes!
thank you!
thank you!
