Dynamic Dashboards and easier theming
Moderator: remb0
Gravityz
- Domoticz version: 2026.3
Re: Dynamic Dashboards and easier theming
before i put in a request on github.
is it possible to make the widgets smaller so we can fit more widgets on 1 screen?
I (and others) have lot's of sensors like standard on/off switches or temperature sensors which do not need a lot of room.
making them square would mean you can fit 2 next 2 each other as compared to the current minimum width
should be rreal easy to implement because at the moment you can resize them but they have a minimal size. lowering the minimal size by a factor of 2 would fix it.(and yes you could end up with unreadable widgets because they need more room but that is already the case with sensors which have a long name.
i would exclude dimmers and selector switches for the obvious reasons
somehow the option to upload files is disabled so i can not show what i mean
- imautohuttraeger
- Domoticz version: latest
I remember there is / was a GitHub feature request already, but I can't find it
Edit: Found it: It was you
, but for Nightglass theme.
https://github.com/galadril/Domoticz-Ni ... issues/287
Stop, look and listen.
Gravityz
Yes indeed and nightglass developer told me this is a domoticz thing.
So some domoticz improvement are inherited by nightglass
apparently this is one of the basic features (widget size)
hopefully they will implement this
imautohuttraeger wrote: Wednesday 04 November 2026 20:24 I remember there is / was a GitHub feature request already, but I can't find it
Edit: Found it: It was you, but for Nightglass theme.
- gizmocuz
You know you have to create a github issue/PR for this right?
Gravityz
Yes i know but i remember when i did a while ago you mentioned this kind of improvements could also be mentioned on the forum (to avoid the amount of issues)
I noticed You are doing a good job of solving all the issues and requests and You are close to 0 (4 at the moment) so i did not want to ruin the moment of accomplishing 0 issues
gizmocuz wrote: Friday 06 November 2026 13:23 You know you have to create a github issue/PR for this right?![]()
- gizmocuz
Hahaha ok, well 0 will not happen, so shoot
- imautohuttraeger
Quick actions only allow to show switches. It would be great, if scenes could also be part of it.
I am thinking of posting a feature request on GitHub, but would like to get feedback here beforehand.
- imautohuttraeger
Just saw, that you can select between devices and scenes while adding items to the list. Honestly, I am not sure if I have simply overseen that, or if it is part of the latest beta that I just installedimautohuttraeger wrote: Monday 09 November 2026 18:27 Quick actions only allow to show switches. It would be great, if scenes could also be part of it.
However - I am happy now!
