Domoticz upcoming beta/release and OpenSSL 3.0
Moderator: remb0
- Varazir
Re: Domoticz upcoming beta/release and OpenSSL 3.0
Got zwave to work as well.
Raspberry PI 2 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
brand new raspbian os, bookworm
fresh Domoticz install
now????
/home/pi/domoticz/domoticz: error while loading shared libraries: libssl.so.1.1
- Domoticz version: 2025.1
Did you install the beta?acaonweb wrote: ↑Sunday 01 June 2025 12:01now????Code: Select all
I did a fresh install here also on new installed bookworm (on Raspberry pi 3B+). No problem.
Also installed the beta on my Ubuntu 24.04 (Virtual machine under Synology). No problem.
Dz on Ubuntu VM on DS718+ behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
- FireWizard
Hi, @acaonweb,
As you have probably installed the latest Domoticz stable 2025.1, you have 2 options.
1. Either install libssl1.1 in Bookworm, so that Domoticz 2025.1 stable and any Domoticz beta, earlier than May 15, will run fine.
2. Install Domoticz, latest beta, so that all future beta's and stable, later than 2025.1 will run fine.
To install libssl1.1 do:
In this case, you should also install:
To use the latest beta do the following:
As you have Domoticz already installed it is sufficient to update to beta
And now.....?now????
sudo apt install libssl1.1
sudo apt install libusb-dev
cd ~/domoticz
sudo ./updatebeta
thanx for your help.. I'm investigating on migrate to docker, so I'm trying toFireWizard wrote: ↑Sunday 01 June 2025 14:48 Hi, @acaonweb,
In this case, you should also install:Code: Select all
To use the latest beta do the following:Code: Select all
RegardsCode: Select all
cd ~/domoticz sudo ./updatebeta
1) create a docker container (check)
2) create a new fresh install on a new SD (to do, thank for the tips above)
3) disable for a while the running service: it's ok to disable it with: sudo systemctl disable domoticz ? and enable again sudo systemctl enable domoticz ??
- FireWizard
HI @acaonweb,
You asked:
or
You asked:
Yes you can do that, but stop Domoticz first3) disable for a while the running service: it's ok to disable it with: sudo systemctl disable domoticz ? and enable again sudo systemctl enable domoticz ??
sudo systemctl stop domoticz
sudo service domoticz stop
Thanx for your suggestion
it's not done with just openSSL 3:
VERSION="11 (bullseye)"
Actually I would like to install an older version, but at the moment I got no idea how to get back... maybe extract from an privious operating SD-card, if possible at all...
All started with an backup-restore wich is not putting back missing mqtt-sensor-datas which for sure are in there as it worked just few hours before. Thought reinstall would be worth an try, but holly shit...
pi@openWB2:~ $ openssl version
OpenSSL 3.3.2 3 Sep 2024 (Library: OpenSSL 3.3.2 3 Sep 2024)
pi@openWB2:~ $ sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
OpenSSL version 3 required!
- Domoticz version: 2024.7
You can always start building your own Domoticz yourself, no problem there. If you want to use the ease of a pre build version just follow the instructions and don not find all kind of shortcuts.
The easiest way if you do not want to build something yourself and want to stay on bullseye is to use docker.
- gizmocuz
Could you tell me the output of the following bash command
openssl version -v | awk '{print $2}' | sed 's/\..*//'
Unfortunately not now, but wil do later. My try & error raspi is from a device at work and it's going somewhere else for the next aprox. 3 weeks.
At my private one I put all together and just touch it again as I fixt my list of open points.
But thanks for the hints as I'm not so firm with linux!
It's strange, cause when I want to add a new Raspberry GPIO hardware in my Domoticz 2025.1 on my Pi 3b with Bookworm this message appears in log console:
"2025-06-11 10:05:38.671 Status: Classic GPIO: This hardware is deprecated. Please transfer to the new SysFS hardware type!"
But there is no more SysFS GPIO with bookworm
- TiXav
I would like to upgrade (not docker), and I made inventory of my system and find the way to make my future system working same/closed to today, I noticed the same thing as you about the GPIO, Have you found a solution since your last message?
Well:
pi@openWB2:~ $ openssl version -v | awk '{print $2}' | sed 's/\..*//'
3
Thanks for the hints. So I tried my own build, but next error occured:waltervl wrote: ↑Saturday 07 June 2025 21:31 You can always start building your own Domoticz yourself, no problem there. If you want to use the ease of a pre build version just follow the instructions and don not find all kind of shortcuts.
CMake Error at /usr/share/cmake-3.18/Modules/FindPackageHandleStandardArgs.cmake:165 (message):
Could NOT find Lua (missing: LUA_LIBRARIES LUA_INCLUDE_DIR) (Required is at
least version "5.3")
Best is to update your system to latest OS....
