All temperature sensors have a white bar. Only one of it has yellow bar.
I know that a red bar appears when there is no update since a longer time. But the respective sensor is updating frequently every 5 minutes.
What does a yellow bar mean?
Meaning of yellow bar Topic is solved
imautohuttraeger
- Domoticz version: 2025.1
- Screenshot_20260117-183117.png (349.48 KiB) Viewed 61 times
- jvdz
- Domoticz version: 4.107
Re: Meaning of yellow bar
Could it be that the battery level is getting low for that particular device?
imautohuttraeger
Ah - thank you, this seems to be the reason. It is a Shelly Plus H&T which can be run with a batterie or with a USB charger. I run it with a USB charger.
