ESP output flickering Topic is solved
Rosomak
Domoticz version: 2023.2
Post by Rosomak »
I have been struggling with this problem for several years and I can't cope.
ESP Output turns on and off very fast after reboot for a few or a dozen or so seconds. (Sometimes this happens when you quickly turn the switch on and off).
Domoticz ver: 2023/2 on Raspberry Pi
ESP_Easy: mega-20231225
Although it doesn't matter because it is not dependent on the software version or whether it is esp32 or esp8266.
It looks as if Domoticz was shouting over ESP Easy and vice versa, how to set the output.
Removing On/Off action from switch settings ends this behavior, but then Im not able to control output from Domoticz dashboard.
Domoticz:
I created dummy hardware with virtual sensor type: Switch with Idx:127
Inside switch settings I created http request to turn on or off ESP output.
ESP Easy:
I created two devices, one for ESP output with Idx: 127 called "Light" and one for ESP input.
I also make one rule:
On System#Boot do
 gpio,14,0
endon
On Input#State=0 do
 if[Light#State]=0
  gpio,14,1
  gpio,14,0
 endif
endon
Its a very minimal setup but is killing me when during night, after ESP reboot due to network failure I have a DISCO at home :(
Any sugestions ?
Domoticz Settings.png (80.41 KiB) Viewed 9687 times
ESP Settings.png (180.28 KiB) Viewed 9687 times
jvdz
Domoticz version: 4.107
Re: ESP output flickering
Post by jvdz »
You do not have the internal pull-up active for gpio14, so do you have a resistor to pull it down or up to garantee it's default state?
Rosomak
Post by Rosomak »
jvdz wrote: Friday 05 January 2024 16:36 You do not have the internal pull-up active for gpio14, so do you have a resistor to pull it down or up to garantee it's default state?
It has no effect. Neither internal pullup nor resistor helps.
There doesn't even have to be an input device and rules can be empty.
Don't tell me that no one has this problem?
RonkA
Domoticz version: 2025.1
Post by RonkA »
Not having this problem myself but maybe:
On System#Boot do
 gpio,4,0
 gpio,14,0
endon
Also do you have debounce set on the swich?
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
Rosomak
Post by Rosomak »
Hi RonkA,
Thank you for your post.
I did a minimal setup now. One device in Domoticz and one device in ESP. No Rules, No PB Switch, External 10k pullup resistor at the output. Please see what is happening with the output when I change the state fast enough.
[youtube]https://youtube.com/shorts/cuNayzz_o9w?feature=share[/youtube]
I noticed it is worst when network is busy. And once again it does not mether I use sonoff, nodemcu, my own design esp8266 or esp32.
One thing that helps a lot is to change "Check Replay:" to 'Check Acknowledgment'.
ESP Settings1.png (203.39 KiB) Viewed 9334 times
Domoticz Settings.png (129.01 KiB) Viewed 9334 times
RonkA
Post by RonkA »
Inputswich called Output... As if live is not complex enough! :lol:
Anyhoe.. i'm no expert but on my Esp's i use the Domoticz HTTP controller for sensors and for swiches i have Domoticz MQTT running..
Why i did it like this is cannot remember but swiching works fine without your described problems in my setup..
Also i don't see the benefit of looping the state of the swich back to the Esp32 with the On- and Off action part..
Maybe try it without the on off triggers.
Rosomak
Post by Rosomak »
RonkA wrote: Wednesday 10 January 2024 13:31 Also i don't see the benefit of looping the state of the swich back to the Esp32 with the On- and Off action part..
Without this funcktion I cant change state by clicking icon in domoticz.
RonkA wrote: Wednesday 10 January 2024 13:31 Anyhoe.. i'm no expert but on my Esp's i use the Domoticz HTTP controller for sensors and for swiches i have Domoticz MQTT running..
I know and you are right, MQTT solves this problem.
After thinking its a time now to move my system to industry 4.0, so I'm facing complete rebuild.
Thanks for help every one.
