I have installed an esp8266 running
https://github.com/SwiCago/HeatPump/tre ... 8266_esp32
in my Mitsubishi heatpump.
This seems to work using Google MqttLens.
So I found this plugin to Domoticz, that I thought I could use:
https://github.com/Masurov/Domoticz-Mit ... QTT-Plugin
which should work with that.
Following the instructions, there should be a device called
"Mitsubishi Heatpump MQTT interface Plugin" in the hardware dropdown list
after installation of plugin and restart of Domoticz.
However, I cannot see this in the dropdown list.
I am running Domoticz 4.11665 on Raspberry-pi with Stretch.
Anyone who could think of why the plugin hardware does not show up?
Thanks for suggestions.
Problems installing plugin Topic is solved
steing
- Domoticz version: 4.11665
echo 659129659305049656388224222264957751972462554378P | dc
steing
Re: Problems installing plugin
I seems as if I cannot install any plugins.
On another RPI, running Buster and Domiticz 2020.2, it works.
Could I be missing some python modules. How would I found out?
HvdW
- Domoticz version: 2023.2
Read the wiki about plugins carefully.
The answer is there.
I had the same issue you have.
Following the instructions solved the problem.
Bugs bug me.
steing
Thanks.
Found the answer here
https://www.domoticz.com/forum/viewtopi ... 75#p163421
Events was disabled in settings.
