As per the subject, I've set it up as per the Wiki then amended the required parts, email etc, I've changed the monitoring freq to 60 secs just for testing and the restart woks Ok if I do a service domoticz stop however I get this error on the port response time
FAILED to [127.0.0.1]:8080/json.htm?type=command¶m=getversion type TCP/IP protocol HTTP
Obviously even though Domoticz is running Ok it will continue to restart it until it hits the maximum cycle time which then forces a reboot, Domoticz is running on port 8080.
TIA
Need some help with Monit Topic is solved
AllesVanZelf
- Domoticz version: 12467
Re: Need some help with Monit
Is 127.0.0.* added to your local network setting in domoticz settings?
Dave21w
- Domoticz version: Stable
It wasn't but I got the same error even after changing it to the IP of Domoticz, after which I spotted the problem - fat finger issue on the keyboard !!
You know what it's like when you've stared at something for so long you can't spot what is right in front of you.
I think it's OK now but thanks for taking the time to respond
