Fibaro wall plug's dumping data while NOT set used in Device list. Topic is solved
KroontjesPen
Domoticz version: 4.10717
Post by KroontjesPen »
Version: V4.10717 b386b49e5
Platform: Windows 10
RFXtrs433E Version: Ext2/1025
Z-Stick Gen 5 Version: 1.4.3244.gbb874f6a.dirty
Fibaro Wall Plug 9x
NodOn remote wall switch
My number of Fibaro Wall Plug's is rising so there data dumping too.
That is very annoying when you are looking for data of devices that are not showing under the Status tab.
In the Device list there are NOT activated. The green arrow's still there.
Will I have to do the blocking per wall switch independently?
Maybe there can created a new tab for this type of log information.
It is difficult to fetch 1 minute of data.
Bear with me, English is not my native language.
Seagate
Re: Fibaro wall plug's dumping data while NOT set used in Device list.
Post by Seagate »
Setting the device to not used will not change the way the hardware behaves.
You need to define how often the wall plugs send out power reports on the configuration pages for the wall plugs themselves.
Setup->hardware-> Zwave controller (Aotec)->setup an then change the appropriate parameters for each wall plug.
