Settings are not persistent Topic is solved
HansieNL
Post by HansieNL »
I hope you understand English, otherwise go to a translation site and drop this message there.
If you all over sudden have problems that settings are not saved anymore then better check your sd-card. I've had it 2 times the sd-card was corrupted and it's then read only. I could change things in Domoticz, but it was all gone after reboot.
You can check if sd-card is corrupted by trying to write a file to the sd-card under Windows. If it says read-only it's better to start using a new sd-card.
Blah blah blah
arnaudarduino
Re: Instelling blijven niet bewaard
Post by arnaudarduino »
Hello HansieNL
When i write somthing to the sd with filezilla ,stays on the sd.
When i change a file with fz too.
arnaudarduino
Re: Settings are not persistent
Where is my question, text ?
