Does anyone know where i can find an overview of the command types i.e "switchlight" used in MQTT publish ?
{"command": "switchlight", "idx": 2450, "switchcmd": "On" }
{"command": "setcolbrightnessvalue", "idx": 2450, "color": {"m":3,"t":0,"r":0,"g":0,"b":50,"cw":0,"ww":0}, "brightness": 40}
{"command": "switchscene", "idx": 24, "switchcmd": "On" }
{"command": "switchscene", "idx": 24, "switchcmd": "Toggle" }
{"command": "sendnotification", "subject": "My Subject", "body": "My Body", "priority": 0, "sound": "mysound" }
thanks
Peter
MQTT Publish command types Topic is solved
- emme
- Domoticz version: latest
Re: MQTT Publish command types
"We always done this way"
In the wiki, there's only the examples, i think there must be a lot of different types.
[Solved] MQTT Publish command types
Solved : I think i can find most of it here :
https://www.domoticz.com/wiki/Domoticz_API/JSON_URL's
br;
Peter
br;
Peter
- Domoticz version: 2023.1
Guys I need help!
I have installed nodered and it looks working.
Now I have to update sensors/switch in domoticz.
One way is with MQTT with MQTT server in the middle and I am not expert on it, where can I find a guide?
Another way is JSON, I think... many forum talk about this page:
so I think it's possible to update without MQTT but simply with a json command like:
/json.htm?type=command¶m=switchlight&idx=99&switchcmd=<On|Off|Toggle|Stop>
am I rigth?
Thanks for the help
Diego
am I rigth?
Thanks for the help
Diego
Raspberry Pi 3b+ - Domoticz 2023.1
NodeRED
Solaredge inverter
NodeRED
Solaredge inverter
- Domoticz version: 2024.7
Did you check the Domoticz MQTT wiki page? https://www.domoticz.com/wiki/MQTT
There is also a specific Node-Red subforum viewforum.php?f=81
