Setup:
- Raspberry Pi model 3b
- Domoticz Version: 3.8153
- P1 cable
- Aeon Labs Aeotec Gen 5 Z-Wave USB Interface on batteries
- 1x Qubino ZMNHADx Flush 1 Relay
- 2x Qubino ZMNHBDx Flush 2 Relays
With the three Qubino devices I can swith 5 devices:
Q1 = Outside lamp 1
Q2.1 = Outside lamp 2
Q2.2 = Indoor lamp
Q3.1 = virtual device 1 (no device connected yet)
Q3.2 = virtual device 2 (no device connected yet)
When I switch on a Group (that contains Q1 and Q2.1 = both oudoor lamps) it sometimes happens that also Q2.2, Q3.1 and Q3.2 switches on. When I use the manual light switch connected to Q1 everything turns on.
I use the following settings for the Qubino ZMNHBDx Flush 2 Relays
I hope somebody can help me out and it's a simple setting that I'm missing
Thanks in advance!
Edit:
It took me a while, but the problem is finally solved. In the Zwave network information* I deleted 1 and 255 in the black circles. After that the problem was solved.
*) Setup > Hardware > Setup Zwave controller> Node Management > Groups and Network
