[SOLVED] Zwave stick works in OZW but not in zwavejs-ui Topic is solved
BartSr
Domoticz version: V2024.7
Post by BartSr »
Hi !
In cannot get the right way to use Zwave stick Aotec Gen5 in docker.
Before I used the Aotec S2 which went without problems.
The guys of Zwavejs-UI told me that S2 is very old so I bought a newer one from dutch Marktplaats.
So far so good. Optimistic I followed the instructions same as for the S2 stick. But..... docker compose ended up with error:
Error response from daemon: error gathering device information while adding custom device "/dev/serial/by-id/usb-0658_0200-if00-port0": no such file or directory
But "/dev/serial/by-id/usb-0658_0200-if00-port0" is valid if OZW is activated in Domoticz hardware.
So how to solve this strange thing.
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2024.7
Re: Zwave stick works in OZW but not in zwavejs-ui
Please post your docker-compose.yml file. Seems something wrong there as it should not mention the real usb port but /dev/zwave
BartSr
Post by BartSr »
version: "3.7"
services:
  zwave-js-ui:
    container_name: zwave-js-ui
    image: zwavejs/zwave-js-ui:latest
    restart: unless-stopped
    tty: true
    stop_signal: SIGINT
    environment:
      - SESSION_SECRET=mySecretSession
      - TZ=Europe/Amsterdam
    devices:
      - '/dev/serial/by-id/usb-0658_0200-if00-port0:/dev/zwave'
    volumes:
      - ./store:/usr/src/app/store
    ports:
      - "8091:8091" # port for web interface
      - "3000:3000" # port for Z-Wave JS websocket server
I also included the screenshot of working OZW.
And yes, of course I disable OZW in domoticz prior to try start zwavejs-ui
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
jvdz
Domoticz version: 4.107
Post by jvdz »
Why do you have the extra bit "-port0" in the docker composer file? That should be exactly the same name as in domoticz.
BartSr
Post by BartSr »
@jvdz
I updated with your remark but still no well-running docker
version: "3.7"
services:
  zwave-js-ui:
    tty: true
    stop_signal: SIGINT
    environment:
    devices:
      - '/dev/serial/by-id/usb-0658_0200-if00:/dev/zwave'
    volumes:
    ports:
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
hvoorend
Domoticz version: 2024.2
Post by hvoorend »
I’m also having troubles to get the Aeon zwave gen5 going (or at least cannot get my ZWaveJS-UI to a stable run. It starts, I do see devices coming into the GUI, but after about a minute the full zwavejs-ui container restarts. And over and over again. I am on Buster.
See https://www.domoticz.com/forum/viewtop ... 24&t=42062. Maybe we can share our experiences.
Raspberry Pi 2
Raspbian Bookworm
Aeon zStick Gen5 fw 1.0
RFXCOM USB
Domoticz 2024.2
BartSr wrote: Wednesday 28 February 2024 23:22 @jvdz
version: "3.7"
services:
  zwave-js-ui:
    tty: true
    stop_signal: SIGINT
    environment:
    devices:
    volumes:
    ports:
Perhaps put the device line in double quotes " instead of single '
See https://github.com/zwave-js/zwave-js-ui/issues/3586
If you can see the Zwavejs website on port 8091 click on save in settings.
After reading some more you probably have the /dev/serial/by-id adress in your Zwave-JS-UI settings. That should be changed into /dev/zwave and then press Save ....
jvdz
Post by jvdz »
Ok, now have a look in the ZWJS2M website (8091) and check the config page for the Docker intername port used for the ZWAVE dongle.
BartSr
Post by BartSr »
@ waltervl
change didnot make a difference
@jvdz
see hereunder but in a second a red message appeared telling no stick connected (or some like that)
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Post by BartSr »
I played a bit with zwave serial port. changed /dev/zwave into /dev/serial/by-id/usb-0658_0200-if00. This ended up in failure. Then I reverted to /dev/zwave and now the devices are there.
Lets wait now if it keeps stable as @hvoorend the container kept starting over and over.
Will post results later today (expect if container is stable for some hours it's OK).
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
jvdz
Post by jvdz »
BartSr wrote: Thursday 29 February 2024 9:40 I played a bit with zwave serial port. changed /dev/zwave into /dev/serial/by-id/usb-0658_0200-if00. This ended up in failure. Then I reverted to /dev/zwave and now the devices are there.
Good to see you got it working and strange you had to presumably save the "/dev/zwave" again to the config, but that was basically the last warning you got, that it was missing the port config.
BartSr
Post by BartSr »
Last to say: thanks to all of you for sharing your knowledge.
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Users browsing this forum: Ahrefs [Bot] and 1 guest
