Dim Qubino ZMNHDD1 with I2/I3 Topic is solved
mcwieger
Domoticz version: 2020.1
Post by mcwieger »
I've bought a number of Qubino ZMNHDD1 dimmers and I want to operate them with a 'double' pulse switch, which is actually created to operate blinds.
Pushing the up switch should dim up, pushing the down switch should dim down.
Question 1: my idea was that this could be realized using the different switches on the dimmer (I1/I2/I3), e.g. use I1 to dim up and I2 to dim down. Reading this forum, that apparently doesn't work, correct? The dim function is only available on I1?
Question 2: if the answer to Q1 is no, can I use one of the switches to set the light to a certain preset (e.g 75%)? In that case I'll use I1 to do basic control (on/off/dim up/dim down) and I2 to set to dim level 75%. Even better would be for I2 to toggle between 75% and off. Is that possible and how?
Thanks in advance for your thoughts!
I moved to HomeAssistant. It was fun while it lasted!
bbqkees
Domoticz version: 4.1x
Re: Dim Qubino ZMNHDD1 with I2/I3
Post by bbqkees »
Change 'Parameter no. 20 – Enable/Disable 3way switch' in the configuration. It enables specifically the mode you ask for in your question 1.
mcwieger
Post by mcwieger »
Thanks. I already checked with Qubino support and they provided the same answer. Will let you know the result after installing and configuring.
mcwieger
Post by mcwieger »
Works perfectly! Dimming up controlled by I1, Dimming down by I2. Switching on/off can be done by both buttons, always switching on to latest dim value.
