Cannot find endpoint map (Qubino ZMNHCD1 Flush shutter) Topic is solved
lewosh
Domoticz version: 3.5140
Post by lewosh »
Last week, I added 2 Qubino ZMNHCD1 (ZWave+ Flush shutter) to my ZWave network without difficulties. Both devices seems to work well except they don't report their statuses, but fortunately there is a workarround thanks to forum users Egrerius and jvdz.
However, everytime I send a command manually or by script to these devices, I see these messages in the Domoticz log file:
2016-03-15 07:20:00.222  EventSystem: Script event triggered: /usr/local/domoticz/var/scripts/lua/script_time_rolluikopen03.lua
2016-03-15 07:20:00.734  Activating Scene/Group: [Rolluiken_Voor]
2016-03-15 07:20:00.735  Activating Scene/Group Device: Rolluik_Living_Voor (On)
2016-03-15 07:20:00.736  OpenZWave: Domoticz has send a Switch command!, Level: 99, NodeID: 2 (0x02)
2016-03-15 07:20:00.737  (ZWaveStick) Light/Switch (Rolluik_Living_Voor)
2016-03-15 07:20:00.813  (ZWaveStick) Light/Switch (Rolluik_Living_Voor)
2016-03-15 07:20:00.825  Activating Scene/Group Device: Rolluik_Bureel_Links (On)
2016-03-15 07:20:00.825  Delaying switch [Rolluik_Bureel_Links] action (Set Level) for 2 seconds
2016-03-15 07:20:00.886  Activating Scene/Group Device: Rolluik_Bureel_Rechts (On)
2016-03-15 07:20:00.886  Delaying switch [Rolluik_Bureel_Rechts] action (Set Level) for 4 seconds
2016-03-15 07:20:02.284  (ZWaveStick) Usage (Unknown)
2016-03-15 07:20:02.286  (ZWaveStick) Usage (Power Meter)
2016-03-15 07:20:02.963  OpenZWave: Domoticz has send a Switch command!, Level: 99, NodeID: 5 (0x05)
2016-03-15 07:20:02.964  (ZWaveStick) Light/Switch (Rolluik_Bureel_Links)
2016-03-15 07:20:03.054  (ZWaveStick) Light/Switch (Rolluik_Bureel_Links)
2016-03-15 07:20:03.983  Executing script: /volume1/@appstore/domoticz/var/scripts/refresh/refresh05.sh
2016-03-15 07:20:15.152  Executing script: /volume1/@appstore/domoticz/var/scripts/refresh/refresh05.sh
2016-03-15 07:20:20.654  (ZWaveStick) Usage (Unknown)
2016-03-15 07:20:20.655  (ZWaveStick) Usage (Power Meter)
2016-03-15 07:20:22.584  (ZWaveStick) Light/Switch (Rolluik_Living_Voor)
2016-03-15 07:20:22.605  (ZWaveStick) Usage (Unknown)
2016-03-15 07:20:22.606  (ZWaveStick) Usage (Power Meter)
2016-03-15 07:20:23.444  (ZWaveStick) Light/Switch (Rolluik_Bureel_Links)
2016-03-15 07:20:24.453 Error, Node005, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_SWITCH_MULTILEVEL endpoint 1
2016-03-15 07:20:24.633 Always,
2016-03-15 07:20:24.633 Always, Dumping queued log messages
2016-03-15 07:20:24.634 Always,
2016-03-15 07:20:24.634 Always, End of queued log message dump
2016-03-15 07:20:26.533  OpenZWave: Domoticz has send a Switch command!, Level: 99, NodeID: 6 (0x06)
2016-03-15 07:20:26.534  (ZWaveStick) Light/Switch (Rolluik_Bureel_Rechts)
2016-03-15 07:20:26.565  Executing script: /volume1/@appstore/domoticz/var/scripts/refresh/refresh05.sh
2016-03-15 07:20:26.624  (ZWaveStick) Light/Switch (Rolluik_Bureel_Rechts)
2016-03-15 07:20:37.894  Executing script: /volume1/@appstore/domoticz/var/scripts/refresh/refresh06.sh
2016-03-15 07:20:47.393  (ZWaveStick) Light/Switch (Rolluik_Bureel_Rechts)
2016-03-15 07:20:48.220  Executing script: /volume1/@appstore/domoticz/var/scripts/refresh/refresh06.sh
2016-03-15 07:20:48.403 Error, Node006, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_SWITCH_MULTILEVEL endpoint 1
2016-03-15 07:20:48.403 Always,
2016-03-15 07:20:48.403 Always, Dumping queued log messages
2016-03-15 07:20:48.404 Always,
2016-03-15 07:20:48.404 Always, End of queued log message dump
2016-03-15 07:20:59.563  Executing script: /volume1/@appstore/domoticz/var/scripts/refresh/refresh06.sh
I already have removed my zwcfg_xxxxxx.xml file and restarted Domoticz and I've tried to exclude and reinclude the devices but no luck.
I also tried user gizmocuz advice without change:
could you goto the openzwave setup, then from the dropdown groups/network
make sure only node 1 is in group 1/2/3
Is there anything else I can do?
I'm on Synology DS213, Aeon Labs USB Z-Stick Gen5, Domoticz V3.4834/OpenZWave 1.4.77 (http://www.jadahl.com/)
Egregius
Domoticz version: v2024.7
Re: Cannot find endpoint map (Qubino ZMNHCD1 Flush shutter)
Post by Egregius »
I don't see those errors. Could be that I removed the Endpoint mapping from the XML before including. Can't remember that.
In the groups I only have node 1 in group 1, nothing else.
gizmocuz
Post by gizmocuz »
it is an OZW error
lewosh
Post by lewosh »
Ok guys, thanks for your quick responses.
I deleted node 1 from group 2 and 3 but that didn't make any difference, the error messages are still there. Thanks anyway!
lewosh
Post by lewosh »
First I did an upgrade to beta v3.0.5070-7 with OZW v1.4.167. Then I deleted the line with <CommandClass id="96" mapping="endpoints" /> in the configuration file ZMNHCDx.xml and all error messages are gone.
Additional good news is that both Qubino modules now report their status correctly without the use of any scripts.
