Zwave Energy Meters Topic is solved
kimhav
Domoticz version: 2023.2
Zwave Energy Meters
Post by kimhav »
While there are quite a few zwave smart plugs available with can provide measurement of electricity used, but are there zwave socket based energy meters available which only monitors the energy used and nothing else? While it doesn't seem so - which zwave smart plug would be recommend if one only have the interest of monitoring the energy used and critical that if there is power outtake that it's not being reset so it's switched off.
roblom
Re: Zwave Energy Meters
Post by roblom »
A Fibaro walli outlet can do all that. Also all Fibaro products are able to remember they're state (it's a setting).
https://www.fibaro.com/en/products/smar ... d-outlets/
FireWizard
Post by FireWizard »
What is the difference?
But perhaps Fibaro: https://www.fibaro.com/en/products/wall-plug/
But a Shelly wall plug is less than halve the price, but uses Wifi and not Zwave.
https://shelly.cloud/products/shelly-pl ... on-device/
But you can check all zwave certified products at: https://products.z-wavealliance.org/reg ... 3/products
kimhav
Post by kimhav »
The difference is that if there is a energy meter which can only monitor the consumption and nothing to avoid any kind of issues as mentioned.
Also why I'm asking is that some devices might quite bad on providing accurate values, so that's why I'm asking. In the past when previously visited this topic there could be up 10% diff on the values reported.
Haven't used any WiFi related devices with Domoticz so haven't read up on how easy they're to get to work. Primary running with zwave devices and secondary some legacy 433mhz sensors.
gizmocuz
Post by gizmocuz »
As mentioned Fibaro/Aeotec are good zwave sockets and you can configure what should happen when a power outage happens (keep it off, switch to last state)
For zigbee you can have a look at (for instance) Tuya TS0121, where you can also specify this behaviour
kimhav
Post by kimhav »
Thanks for the input and I went for the Fibaro wall plug which was works as fine and even have settings to disable the button on the device itself to avoid that the plug disabled accidentality and yes it returns to the previous state directly after power outage.
