Aeotec multisensor 6 Topic is solved
SebastiaanCT
Post by SebastiaanCT »
Today I have added the multisensor 6 to my domoticz system. (2020.2 on Pi4)
But I'm missing the temp and hum sensor? I have excluded and factory reset the sensor. But the same result after including the sensor again.
Does anyone know what's going wrong here?
Thnx.
Aeotec m6.PNG (32.35 KiB) Viewed 813 times
TSkar
Domoticz version: 2.13055
Re: Aeotec multisensor 6
Post by TSkar »
When I installed those it took a while (hours) before all sensors showed up as devices, when running on battery.
The ones powered by USB was done in minutes (1-15?)
- Set system to accept new devices, not just for five minutes; I forget this almost every time I install new hardware..
SebastiaanCT
Hi TSkar,
Thank you for you reply. It worked.
