General setting for polling? Topic is solved
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
I'm pretty sure I read somewhere in the past in this forum about a general setting for Domoticz for the z-wave polling. If I remember well, the setting had to be based a bit on the number of Z-wave nodes on the network. Maybe I dreamt it :) but I cannot find it anymore... has this disappeared now?
Running RPI V3.8153
Basically my network has increased quite a lot over the last year and the value I set a while back is creating me problems now. I need to change it.
I read about individual polling per device... but if it is a generic one as in the past, easier for me. - Unless I have dreamt it! :D
11101101 - www.machinon.com
Egregius
Domoticz version: v2024.7
Re: General setting for polling?
Post by Egregius »
Do not enable polling, only enable it for nodes that don't report their status automatically.
EdddieN
Post by EdddieN »
Yes, I do seem too have some nodes that do not seem to report on themselves.
Is there a way writhing Domoticz to set the generic interval? I’m pretty sure I did change it somewhere in the past
EdddieN
Post by EdddieN »
Just to clarify, I do not enable polling to all the nodes. Just a few that seem too die otherwise, as my network has grown.... so the chances of lazy nodes
Egregius
Post by Egregius »
You can set the general polling interval on the zwave table. Select the controller and choose a interval. Although I only have 2 nodes with polling enabled mine is set to 120 seconds.
EdddieN
Post by EdddieN »
That is exactly what I was looking for!
For clarification only, I have mine to 600 seconds. If I have 2 devices with polling, basically the controller has 10 minutes to poll both nodes. In this case plenty of time. Correct?
