ZW075 Smart Switch Gen5 Topic is solved
Varazir
Post by Varazir »
I have bought this and according to the webstore it should report back consumption as well.
I can only find the switch in devices.
Checking current values in the OpenZWave Control Panel I only see Swtich.
Domoticz V3.5964
Keep seeing this in the OpenZWave control panel if I enable polling
2016-11-19 16:44:15.103 Error, Node011, ERROR: Dropping command because node is presumed dead
2016-11-19 16:44:15.104 Always,
2016-11-19 16:44:15.104 Always, Dumping queued log messages
2016-11-19 16:44:15.105 Always,
2016-11-19 16:44:15.105 Always, End of queued log message dump
2016-11-19 16:45:16.337 Error, Node011, ERROR: Dropping command because node is presumed dead
2016-11-19 16:45:16.338 Always,
2016-11-19 16:45:16.338 Always, Dumping queued log messages
2016-11-19 16:45:16.339 Always,
2016-11-19 16:45:16.339 Always, End of queued log message dump
2016-11-19 16:46:17.563 Error, Node011, ERROR: Dropping command because node is presumed dead
2016-11-19 16:46:17.567 Always,
2016-11-19 16:46:17.568 Always, Dumping queued log messages
2016-11-19 16:46:17.569 Always,
2016-11-19 16:46:17.569 Always, End of queued log message dump
2016-11-19 16:46:17.570 Always,
Edit:
Tested to add this https://github.com/OpenZWave/open-zwave ... /zw075.xmland restart domoticz
This is what the logs say
2016-11-20 14:19:26.786 OpenZWave: Value_Added: Node: 11 (0x0b), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-11-20 14:19:28.999 Hardware Monitor: Fetching data (System sensors)
2016-11-20 14:19:50.151 OpenZWave: Received timeout notification from HomeID: 3260666225, NodeID: 11 (0x0b)
2016-11-20 14:20:02.201 OpenZWave: Received timeout notification from HomeID: 3260666225, NodeID: 11 (0x0b)
2016-11-20 14:20:02.543 OpenZWave: All Nodes queried
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Varazir
Re: ZW075 Smart Switch Gen5
Post by Varazir »
Varazir
Post by Varazir »
latest update did the trick
