SolarEdge production throttling from Domoticz
jvdz
Domoticz version: 4.107
Re: SolarEdge production throttling from Domoticz
Post by jvdz »
Did some GITHUB Branches cleanup and updated this in the first post at the bottom:
There are currently 3 Branches:
Original Master (v1.2.3) updated with the active_power_limit Dimmer&Sync option:
https://github.com/jvanderzande/domotic ... tcp-plugin
Original METERS (v2.0.4) updated with the active_power_limit Dimmer&Sync option:
https://github.com/jvanderzande/domotic ... ree/meters
Development based on my meters branch using the latest solaredge_modbus and Selector Switches for Battery modes:
https://github.com/jvanderzande/domotic ... /MetersDev
Documentation still needs work, but that will happen too someday when development is done. :D
jannl
Domoticz version: 2022.2
Post by jannl »
Anyone did any checks on the net solarpower? The modbua valua is the AC value, as soon as the battery is being charges the value does not add up. Compare it to the value in the app (but remember it is a lot slower).
For now I use a lua script based on the battery being charged or not, the meter values ans the ev charger power for which I now have a very small plugin that only reads 1 modbua value from the charger.
imautohuttraeger
Domoticz version: 2025.1
Post by imautohuttraeger »
jannl wrote: Wednesday 18 June 2025 19:14 Anyone did any checks on the net solarpower? The modbua valua is the AC value, as soon as the battery is being charges the value does not add up. Compare it to the value in the app (but remember it is a lot slower).
That's why getting these two devices would be excellent to have:
Pure solar production (not the net value)
Pure battery charge / discharge
Unfortunately I can't test it currently (traveling).
jannl
Post by jannl »
I can and the pure solar productuon is not a modbus value. So as ling as youbdon't charge a battery it is not problem.
imautohuttraeger
Will soon be back from traveling on the job. So I hope to find some time next week to install and test. Is MetersDev the correct branch to take? Can I install it in parallel or will it overwrite the existing Hardware in Domoticz? Do I have to observe anything on top of the original instructions on Github?
Sorry, I am not really savy with it ...
jvdz
Post by jvdz »
Just have a look at my first post in this thread which is updated with the latest Status.
I don't know if you can run multiple instances of the plugin on your setup, but i couldn't and had to add any extra docker container that performs the role of modbus proxy after which i can run multiple.
For each change you will have to Perform the pip command to update the docker with the requirement.txt content.
I have added the required command to customstart.sh :
  pip3 install -r /opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/requirements.txt
so it is done with each creation of the domoticz container.
I am hoping that somebody with an battery installation can give me some feedback on the MetersDev branch whether or not those Selector switched work and are usefull.
imautohuttraeger
Sorry, that i took so long. Finally now I have de-installed the current master and installed the MetersDev Branch. There are more devices now including the dimmer switch - see Screenshot. But there is no batterie.
Do I use the correct versions?
Version: 0.8.0
Version: 3.6.9
jvdz
Post by jvdz »
You will have to change the logging to debug and then save the hardware which will restart the plugin. A lot of messages will capture in the domoticz log. Please send that log to my email address and then change the logging back to normal.
imautohuttraeger
jvdz wrote: Wednesday 02 July 2025 9:15 You will have to change the logging to debug and then save the hardware which will restart the plugin. A lot of messages will capture in the domoticz log. Please send that log to my email address and then change the logging back to normal.
Just have sent you a PM with the log data (don't know your email).
