New Python plugin: Domoticz SolarEdge_ModbusTCP
AddieJanssen
Re: New Python plugin: Domoticz SolarEdge_ModbusTCP
Post by AddieJanssen »
imautohuttraeger wrote: Saturday 10 October 2026 1:01 EDIT: Next morning, when the battery is charged again, it is back to normal again (both status devices show "charge").
Maybe this is a standard behaviour, but I thought it might not be harmful to notify this:
Today is the first day since March (Heavy rain and dark clouds all over the day) ,where my Battery was sucked empty.
Battery1 - State of Energy:
"0"
And I recognized the following findings:
Battery1 - Status:
"Key not found in lookup table: 10"
(normally it is Idle, Charge or Discharge)
Battery1 - Internal Status:
"Fault"
According to the SolarEdge documentation that I have, there's no such status as "10".
However, I looked at a Home Assistant plugin, they list this: 10: "B_STATUS_POWER_SAVING"
They have a whole bunch more information where it is unclear where they got it from, but interesting to have a peek at in the future.
hskip
Post by hskip »
I ran the scanner again (with the 15-second setting) on ​​the SE3000, no battery.
python scanner.py 192.168.178.77 502
Connecting to server
Connected to server
Looking for SunSpec identifier at address [40000 (0x9c40)] for device [1]
The inverter is providing a SunSpec Map
Reading Block at address [40002 (0x9c42)] for device [1]
ERROR: request ask for transaction_id=2 but got id=1, Skipping.
Block id = [1]
Block length = [65]
=================================================================== DEVICE DETAILS ===================================================================
[id] [1]
[name] [common]
[label] [Common]
[description] [All SunSpec compliant devices must include this as the first model]
-------------------------------------------------------------------- MEASUREMENTS --------------------------------------------------------------------
[id] [Model identifier] [1]
[l] [Model length] [65]
[mn] [Well known value registered with SunSpec for compliance] [SolarEdge ]
[md] [Manufacturer specific value (32 chars)] [SE3000]
[opt] [Manufacturer specific value (16 chars)] []
[vr] [Manufacturer specific value (16 chars)] [0003.2537]
[sn] [Manufacturer specific value (32 chars)] [7F190BC7]
[da] [Modbus device address] [1]
Reading Block at address [40069 (0x9c85)] for device [1]
Block id = [101]
Block length = [50]
[id] [101]
[name] [inverter_single_phase]
[label] [Inverter (Single Phase)]
[description] [Include this model for single phase inverter monitoring]
[id] [Model identifier] [101]
[l] [Model length] [50]
[a] [AC Current] [0]
[apha] [Phase A Current] [0]
[aphb] [Phase B Current] [NOT_IMPLEMENTED]
[aphc] [Phase C Current] [NOT_IMPLEMENTED]
[a_sf] [] [0]
[ppvphab] [Phase Voltage AB] [230.70] = [2307 * (10**-1)] using scale factor [v_sf]
[ppvphbc] [Phase Voltage BC] [NOT_IMPLEMENTED]
[ppvphca] [Phase Voltage CA] [NOT_IMPLEMENTED]
[phvpha] [Phase Voltage AN] [NOT_IMPLEMENTED]
[phvphb] [Phase Voltage BN] [NOT_IMPLEMENTED]
[phvphc] [Phase Voltage CN] [NOT_IMPLEMENTED]
[v_sf] [] [-1]
[w] [AC Power] [0]
[w_sf] [] [0]
[hz] [Line Frequency] [50.01] = [50013 * (10**-3)] using scale factor [hz_sf]
[hz_sf] [] [-3]
[va] [AC Apparent Power] [0]
[va_sf] [] [0]
[var] [AC Reactive Power] [0]
[var_sf] [] [0]
[pf] [AC Power Factor] [100.00] = [10000 * (10**-2)] using scale factor [pf_sf]
[pf_sf] [] [-2]
[wh] [AC Energy] [41970476.00] = [41970476 * (10**0)] using scale factor [wh_sf]
[wh_sf] [] [0]
[dca] [DC Current] [0]
[dca_sf] [] [0]
[dcv] [DC Voltage] [1.20] = [12 * (10**-1)] using scale factor [dcv_sf]
[dcv_sf] [] [-1]
[dcw] [DC Power] [0]
[dcw_sf] [] [0]
[tmpcab] [Cabinet Temperature] [NOT_IMPLEMENTED]
[tmpsnk] [Heat Sink Temperature] [0]
[tmptrns] [Transformer Temperature] [NOT_IMPLEMENTED]
[tmpot] [Other Temperature] [NOT_IMPLEMENTED]
[tmp_sf] [] [-2]
[st] [Enumerated value. Operating state] [STARTING]
[stvnd] [Vendor specific operating state code] [0]
[evt1] [Bitmask value. Event fields] [NOT_IMPLEMENTED]
[evt2] [Reserved for future use] [NOT_IMPLEMENTED]
[evtvnd1] [Vendor defined events] [0]
[evtvnd2] [Vendor defined events] [NOT_IMPLEMENTED]
[evtvnd3] [Vendor defined events] [NOT_IMPLEMENTED]
[evtvnd4] [Vendor defined events] [0]
Reading Block at address [40121 (0x9cb9)] for device [1]
Block id = [65535]
Block length = [0]
Block type = [The End of the block list has been reached]
End of SunSpec MAP
Looking for Battery at address [57600 (0xe100)] for device [1]
No battery found at this address
Looking for Battery at address [57856 (0xe200)] for device [1]
Disconnected from server
imautohuttraeger
Domoticz version: latest
Post by imautohuttraeger »
hskip wrote: Sunday 11 October 2026 22:39 [...] (with the 15-second setting) [...]
Seems I have missed something. What is the "15-second setting"? Shall we other testers run it with this option, too?
Stop, look and listen.
hskip
Post by hskip »
AddieJanssen wrote: Thursday 08 October 2026 10:24 Are these results from the scanner with the increased timeout?
Please check line 168 of the scanner. It should read:
line 168: client = ModbusTcpClient(host=args.host, port=args.port, timeout=15)
eddieb
Post by eddieb »
The github version is correct ...
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
hjzwiers
Post by hjzwiers »
Have you gotten stuck or something, you started so hopefull?
I looked into the diffences between jvdz's version and yours and why your reaction was so odd, it's this difference:
  # Set Selector switch level to 0;10;20;30 ....
                        if (unit[Column.ID] == inverters.InverterUnit.STORAGECONTROL ) \
                        or (unit[Column.ID] == inverters.InverterUnit.RCCMDMODE ) \
                        or (unit[Column.ID] == inverters.InverterUnit.STORAGE_AC_CHARGE_POLICY ):
                            sValue = unit[Column.FORMAT].format(value*10)
                            if value > 0:
                                nValue = 2
                            # EXTRATEST = True
i couldnt find these in your version 2.07
AddieJanssen
No worries - working on it and so far there are no showstoppers - just running out of time on a daily basis :) We had a heat pump installed and that consumed a lot of time. And every now and then, I need to work as well....
imautohuttraeger
AddieJanssen wrote: Sunday 25 October 2026 17:37 [...]We had a heat pump installed [...]
Very good decision. I envy you for using energy from the soil. I only a have mine working with the energy of the air. However, even this saved me about 600 € per year compared to the old gas heating. And about 400 € on top that came from the solar panels. So summing up about 1000 €.
AddieJanssen
A quick update on where we are:
I have a first 2.1.x version of the plugin working that does not depend on the solaredge_modbus library of nmakel anymore and allows us to update pymodbus to the latest version.
The updated plugin uses the scan functionality as introduced with the scanner tool that we used here over the last month.
I deployed the new plugin to my test setup just now and will let it run for a few days to see if the results make sense and if it does not crash.
Unless my test shows tons of issues, I am planning to release this version later this week.
This is a major rewrite of the plugin, so for sure not a candidate that you want to copy over your current running plugin.
But more on that later.
imautohuttraeger
Great news. I think it is about time for me to finally establish a second system for testing apart from the RasPi ;-)
Maybe an old outdated laptop could do this job.
AddieJanssen
New DEV version of the plugin released
I just published version 3.0.0-dev.1 on GitHub. This version has run without issues in my test environment for the last week. However, I do not have any meters or batteries attached to my inverter. Especially the battery functionality is untested - expect it to fail and if it does, share as much log/error information as possible. Also share your feedback if there are no issues - a confirmation that things "just work" is also valuable at this stage.
This is the first (pre-release) of the 3.x.x version of the plugin and is a major rewrite of the plugin. This version should be considered as an alpha version - it needs testing and community feedback! The main focus of this version was to replace the (archived) solaredge_modbus library and to fix the errors in battery detection.
Details can be found here: https://github.com/addiejanssen/domotic ... .0.0-dev.1 PLEASE read the information on that page BEFORE installing this version and DO NOT OVERWRITE your current plugin. Be aware of the Missing functionality before using this version.
Enjoy and let me know if/how it works!
Regards,
Addie
Filip
Post by Filip »
Hi Addie,
First of all, thank you for your work.
Using domoticz since +10 years, I am using already 2 years a tweaked version of your 1.1.1 plugin. I had to make some changes to make it working... Currently I have only solar panels with a SolarEdge invertor. I was happy reading your post with the possibility to switch to the "standard" (your) version. But seems I running back into troubles. I installed your version aside the existing one as indicated.
How could I help you to make this also working in my environment?
Below an extract of the log.
2026-11-05 20:05:41.108  Status: TESTSolarEdgeNew: Stop directive received.
2026-11-05 20:05:41.109  TESTSolarEdgeNew: Disconnected from: 192.168.1.58:1502 Device Address: 1
2026-11-05 20:05:41.114  Status: TESTSolarEdgeNew: Exiting work loop.
2026-11-05 20:05:41.208  Status: TESTSolarEdgeNew: Stopping threads.
2026-11-05 20:05:41.208  Status: TESTSolarEdgeNew: Stopped.
2026-11-05 20:05:41.209  Status: TESTSolarEdgeNew: Entering work loop.
2026-11-05 20:05:41.209  Status: TESTSolarEdgeNew: Started.
2026-11-05 20:05:41.538  Status: TESTSolarEdgeNew: Initialized version 3.0.0-dev.1, author 'Addie Janssen'
2026-11-05 20:05:41.550  TESTSolarEdgeNew: Connection established with: 192.168.1.58:1502 Device Address: 1
2026-11-05 20:05:42.336  TESTSolarEdgeNew: Inverter returned device information
2026-11-05 20:05:42.337  TESTSolarEdgeNew: Found [Common]
2026-11-05 20:05:42.337  TESTSolarEdgeNew: Found [Inverter (Single Phase)]
2026-11-05 20:05:42.337  TESTSolarEdgeNew: Found a [Inverter]
2026-11-05 20:05:42.337  TESTSolarEdgeNew:  Found [Status]
2026-11-05 20:05:42.337  TESTSolarEdgeNew: [TextStatusDevice]  Check if device [TESTSolarEdgeNew - Status] needs updating
2026-11-05 20:05:42.337  TESTSolarEdgeNew: [TextStatusDevice]   No Update needed
2026-11-05 20:05:42.337  TESTSolarEdgeNew:  Found [Vendor Status]
2026-11-05 20:05:42.337  TESTSolarEdgeNew: [TextStatusDevice]  Check if device [TESTSolarEdgeNew - Vendor Status] needs updating
2026-11-05 20:05:42.338  TESTSolarEdgeNew: [TextStatusDevice]   No Update needed
2026-11-05 20:05:42.338  TESTSolarEdgeNew:  Found [Current]
2026-11-05 20:05:42.338  TESTSolarEdgeNew: [CurrentDevice]  Check if device [TESTSolarEdgeNew - Current] needs updating
2026-11-05 20:05:42.338  TESTSolarEdgeNew: [CurrentDevice]   No Update needed
2026-11-05 20:05:42.338  TESTSolarEdgeNew:  Found [L1 Current]
2026-11-05 20:05:42.338  TESTSolarEdgeNew: [CurrentDevice]  Check if device [TESTSolarEdgeNew - L1 Current] needs updating
2026-11-05 20:05:42.338  TESTSolarEdgeNew:  Found [L1 Voltage]
2026-11-05 20:05:42.338  TESTSolarEdgeNew: [VoltageDevice]  Check if device [TESTSolarEdgeNew - L1 Voltage] needs updating
2026-11-05 20:05:42.339  TESTSolarEdgeNew: [VoltageDevice]   No Update needed
2026-11-05 20:05:42.339  TESTSolarEdgeNew:  Found [L1-N Voltage]
2026-11-05 20:05:42.339  TESTSolarEdgeNew: [VoltageDevice]  Check if device [TESTSolarEdgeNew - L1-N Voltage] needs updating
2026-11-05 20:05:42.339  TESTSolarEdgeNew:  Found [Power]
2026-11-05 20:05:42.339  TESTSolarEdgeNew: [PowerDevice]  Check if device [TESTSolarEdgeNew - Power] needs updating
2026-11-05 20:05:42.339  TESTSolarEdgeNew: [PowerDevice]   No Update needed
2026-11-05 20:05:42.339  TESTSolarEdgeNew:  Found [Frequency]
2026-11-05 20:05:42.340  TESTSolarEdgeNew: [FrequencyDevice]  Check if device [TESTSolarEdgeNew - Frequency] needs updating
2026-11-05 20:05:42.340  TESTSolarEdgeNew: [FrequencyDevice]   No Update needed
2026-11-05 20:05:42.340  TESTSolarEdgeNew:  Found [Power (Apparent)]
2026-11-05 20:05:42.340  TESTSolarEdgeNew: [ApparentPowerDevice]  Check if device [TESTSolarEdgeNew - Power (Apparent)] needs updating
2026-11-05 20:05:42.340  TESTSolarEdgeNew: [ApparentPowerDevice]   No Update needed
2026-11-05 20:05:42.341  TESTSolarEdgeNew:  Found [Power (Reactive)]
2026-11-05 20:05:42.341  TESTSolarEdgeNew: [ReactivePowerDevice]  Check if device [TESTSolarEdgeNew - Power (Reactive)] needs updating
2026-11-05 20:05:42.341  TESTSolarEdgeNew: [ReactivePowerDevice]   No Update needed
2026-11-05 20:05:42.342  TESTSolarEdgeNew:  Found [Power Factor]
2026-11-05 20:05:42.342  TESTSolarEdgeNew: [PercentageDevice]  Check if device [TESTSolarEdgeNew - Power Factor] needs updating
2026-11-05 20:05:42.342  TESTSolarEdgeNew: [PercentageDevice]   No Update needed
2026-11-05 20:05:42.342  TESTSolarEdgeNew:  Found [Total Energy]
2026-11-05 20:05:42.343  TESTSolarEdgeNew: [EnergyDevice]  Check if device [TESTSolarEdgeNew - Total Energy] needs updating
2026-11-05 20:05:42.343  TESTSolarEdgeNew: [EnergyDevice]   No Update needed
2026-11-05 20:05:42.344  TESTSolarEdgeNew:  Found [DC Current]
2026-11-05 20:05:42.344  TESTSolarEdgeNew: [CurrentDevice]  Check if device [TESTSolarEdgeNew - DC Current] needs updating
2026-11-05 20:05:42.344  TESTSolarEdgeNew: [CurrentDevice]   No Update needed
2026-11-05 20:05:42.344  TESTSolarEdgeNew:  Found [DC Voltage]
2026-11-05 20:05:42.344  TESTSolarEdgeNew: [VoltageDevice]  Check if device [TESTSolarEdgeNew - DC Voltage] needs updating
2026-11-05 20:05:42.345  TESTSolarEdgeNew: [VoltageDevice]   No Update needed
2026-11-05 20:05:42.345  TESTSolarEdgeNew:  Found [DC Power]
2026-11-05 20:05:42.345  TESTSolarEdgeNew: [PowerDevice]  Check if device [TESTSolarEdgeNew - DC Power] needs updating
2026-11-05 20:05:42.345  TESTSolarEdgeNew: [PowerDevice]   No Update needed
2026-11-05 20:05:42.346  TESTSolarEdgeNew:  Found [Temperature]
2026-11-05 20:05:42.346  TESTSolarEdgeNew: [TemperatureDevice]  Check if device [TESTSolarEdgeNew - Temperature] needs updating
2026-11-05 20:05:42.346  TESTSolarEdgeNew: [TemperatureDevice]   No Update needed
2026-11-05 20:05:42.346  TESTSolarEdgeNew: Found [Unknown]
2026-11-05 20:05:42.347  TESTSolarEdgeNew: Found [Unknown]
2026-11-05 20:05:42.348  TESTSolarEdgeNew: Found [Unknown]
2026-11-05 20:05:42.349  TESTSolarEdgeNew: Found [Unknown]
2026-11-05 20:06:41.061  TESTSolarEdgeNew: We have 1 devices
2026-11-05 20:06:41.062  TESTSolarEdgeNew: Start processing [Inverter]
2026-11-05 20:06:41.098  TESTSolarEdgeNew:  [Status] value has not changed and last update is too fresh
2026-11-05 20:06:41.100  TESTSolarEdgeNew:  [Vendor Status] value has not changed and last update is too fresh
2026-11-05 20:06:41.102  TESTSolarEdgeNew:  [Current] value has not changed and last update is too fresh
2026-11-05 20:06:41.104  TESTSolarEdgeNew:  [L1 Current] value has not changed and last update is too fresh
2026-11-05 20:06:41.106  TESTSolarEdgeNew:  [L1 Voltage] updating value to [227.10]
2026-11-05 20:06:41.112  TESTSolarEdgeNew:  [L1-N Voltage] updating value to [227.10]
2026-11-05 20:06:41.122  TESTSolarEdgeNew:  [Power] value has not changed and last update is too fresh
2026-11-05 20:06:41.123  TESTSolarEdgeNew:  [Frequency] updating value to [49.99]
2026-11-05 20:06:41.132  TESTSolarEdgeNew:  [Power (Apparent)] value has not changed and last update is too fresh
2026-11-05 20:06:41.134  TESTSolarEdgeNew:  [Power (Reactive)] value has not changed and last update is too fresh
2026-11-05 20:06:41.136  TESTSolarEdgeNew:  [Power Factor] value has not changed and last update is too fresh
2026-11-05 20:06:41.138  TESTSolarEdgeNew:  [Total Energy] value has not changed and last update is too fresh
2026-11-05 20:06:41.140  Error: TESTSolarEdgeNew: Call to function 'onHeartbeat' failed, exception details:
2026-11-05 20:06:41.152  Error: TESTSolarEdgeNew: Traceback (most recent call last):
2026-11-05 20:06:41.152  Error: TESTSolarEdgeNew:   File "/opt/domoticz/userdata/plugins/SolarEdgeNew/plugin.py", line 125, in onHeartbeat
2026-11-05 20:06:41.153  Error: TESTSolarEdgeNew:     _plugin.onHeartbeat()
2026-11-05 20:06:41.153  Error: TESTSolarEdgeNew:     ~~~~~~~~~~~~~~~~~~~^^
2026-11-05 20:06:41.154  Error: TESTSolarEdgeNew:   File "/opt/domoticz/userdata/plugins/SolarEdgeNew/base.py", line 138, in onHeartbeat
2026-11-05 20:06:41.156  Error: TESTSolarEdgeNew:     if device.updateDomoticzValue(domoticz_devices=self._domoticz_devices, now=now):
2026-11-05 20:06:41.157  Error: TESTSolarEdgeNew:        ~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-11-05 20:06:41.157  Error: TESTSolarEdgeNew:   File "/opt/domoticz/userdata/plugins/SolarEdgeNew/domo/base.py", line 115, in updateDomoticzValue
2026-11-05 20:06:41.158  Error: TESTSolarEdgeNew:     sValue: str = self.update()
2026-11-05 20:06:41.158  Error: TESTSolarEdgeNew:                   ~~~~~~~~~~~^^
2026-11-05 20:06:41.159  Error: TESTSolarEdgeNew:   File "/opt/domoticz/userdata/plugins/SolarEdgeNew/domo/base.py", line 97, in update
2026-11-05 20:06:41.159  Error: TESTSolarEdgeNew:     primary = self._calculator.update(primary)
2026-11-05 20:06:41.159  Error: TESTSolarEdgeNew:   File "/opt/domoticz/userdata/plugins/SolarEdgeNew/domo/calculators.py", line 29, in update
2026-11-05 20:06:41.159  Error: TESTSolarEdgeNew:     return self.get()
2026-11-05 20:06:41.160  Error: TESTSolarEdgeNew:            ~~~~~~~~^^
2026-11-05 20:06:41.160  Error: TESTSolarEdgeNew:   File "/opt/domoticz/userdata/plugins/SolarEdgeNew/domo/calculators.py", line 67, in get
2026-11-05 20:06:41.160  Error: TESTSolarEdgeNew:     sum_value: float = sum(value for _, value in self.samples)
2026-11-05 20:06:41.161  Error: TESTSolarEdgeNew:                        ~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-11-05 20:06:41.161  Error: TESTSolarEdgeNew: TypeError: unsupported operand type(s) for +: 'int' and 'NoneType'
2026-11-05 20:07:41.082  TESTSolarEdgeNew: We have 1 devices
2026-11-05 20:07:41.083  TESTSolarEdgeNew: Start processing [Inverter]
2026-11-05 20:07:41.116  TESTSolarEdgeNew:  [Status] value has not changed and last update is too fresh
2026-11-05 20:07:41.117  TESTSolarEdgeNew:  [Vendor Status] value has not changed and last update is too fresh
2026-11-05 20:07:41.119  TESTSolarEdgeNew:  [Current] value has not changed and last update is too fresh
2026-11-05 20:07:41.122  TESTSolarEdgeNew:  [L1 Current] value has not changed and last update is too fresh
2026-11-05 20:07:41.124  TESTSolarEdgeNew:  [L1 Voltage] updating value to [227.05]
2026-11-05 20:07:41.133  TESTSolarEdgeNew:  [L1-N Voltage] updating value to [227.05]
2026-11-05 20:07:41.144  TESTSolarEdgeNew:  [Power] value has not changed and last update is too fresh
2026-11-05 20:07:41.147  TESTSolarEdgeNew:  [Frequency] updating value to [50.00]
2026-11-05 20:07:41.154  TESTSolarEdgeNew:  [Power (Apparent)] value has not changed and last update is too fresh
2026-11-05 20:07:41.156  TESTSolarEdgeNew:  [Power (Reactive)] value has not changed and last update is too fresh
2026-11-05 20:07:41.158  TESTSolarEdgeNew:  [Power Factor] value has not changed and last update is too fresh
2026-11-05 20:07:41.160  TESTSolarEdgeNew:  [Total Energy] value has not changed and last update is too fresh
2026-11-05 20:07:41.162  Error: TESTSolarEdgeNew: Call to function 'onHeartbeat' failed, exception details:
2026-11-05 20:07:41.175  Error: TESTSolarEdgeNew: Traceback (most recent call last):
2026-11-05 20:07:41.175  Error: TESTSolarEdgeNew:   File "/opt/domoticz/userdata/plugins/SolarEdgeNew/plugin.py", line 125, in onHeartbeat
2026-11-05 20:07:41.175  Error: TESTSolarEdgeNew:     _plugin.onHeartbeat()
2026-11-05 20:07:41.176  Error: TESTSolarEdgeNew:     ~~~~~~~~~~~~~~~~~~~^^
2026-11-05 20:07:41.176  Error: TESTSolarEdgeNew:   File "/opt/domoticz/userdata/plugins/SolarEdgeNew/base.py", line 138, in onHeartbeat
2026-11-05 20:07:41.176  Error: TESTSolarEdgeNew:     if device.updateDomoticzValue(domoticz_devices=self._domoticz_devices, now=now):
2026-11-05 20:07:41.177  Error: TESTSolarEdgeNew:        ~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-11-05 20:07:41.177  Error: TESTSolarEdgeNew:   File "/opt/domoticz/userdata/plugins/SolarEdgeNew/domo/base.py", line 115, in updateDomoticzValue
2026-11-05 20:07:41.179  Error: TESTSolarEdgeNew:     sValue: str = self.update()
2026-11-05 20:07:41.179  Error: TESTSolarEdgeNew:                   ~~~~~~~~~~~^^
2026-11-05 20:07:41.179  Error: TESTSolarEdgeNew:   File "/opt/domoticz/userdata/plugins/SolarEdgeNew/domo/base.py", line 97, in update
2026-11-05 20:07:41.180  Error: TESTSolarEdgeNew:     primary = self._calculator.update(primary)
2026-11-05 20:07:41.180  Error: TESTSolarEdgeNew:   File "/opt/domoticz/userdata/plugins/SolarEdgeNew/domo/calculators.py", line 29, in update
2026-11-05 20:07:41.180  Error: TESTSolarEdgeNew:     return self.get()
2026-11-05 20:07:41.180  Error: TESTSolarEdgeNew:            ~~~~~~~~^^
2026-11-05 20:07:41.180  Error: TESTSolarEdgeNew:   File "/opt/domoticz/userdata/plugins/SolarEdgeNew/domo/calculators.py", line 67, in get
2026-11-05 20:07:41.181  Error: TESTSolarEdgeNew:     sum_value: float = sum(value for _, value in self.samples)
2026-11-05 20:07:41.181  Error: TESTSolarEdgeNew:                        ~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-11-05 20:07:41.181  Error: TESTSolarEdgeNew: TypeError: unsupported operand type(s) for +: 'int' and 'NoneType'
imautohuttraeger
Filip wrote: Thursday 05 November 2026 20:20 Below an extract of the log.
OFFTOPIC: Hi @Filip: It would be nice, if you edit the post and place a long output like this between the "code" markup
Hint: I am aware that you are not the only user who is pasting log output or code directly to the text.
We need less scrolling through the thread then.Thank you in advance!
AddieJanssen
Filip wrote: Thursday 05 November 2026 20:20 Hi Addie,
Hi Filip,
Congratulations, looks like you found the first bug :D
I am going to contact you via a private message to figure out what is happening.
imautohuttraeger
This is just to give you a live-sign. I hope I can install it tomorrow 3.0.0-dev.1 and will report then.
AddieJanssen
Be aware: the issues that Filip found are now also showing on my test server.
So this version has issues....
I am investigating what is going on, but it will take a bit of time to release a new version.
imautohuttraeger
I understand. So I guess my log data would not help for your first bug-tracking. So I better wait for the next release of the DEV.
