New Python plugin: Domoticz SolarEdge_ModbusTCP
- imautohuttraeger
- Domoticz version: latest
Re: New Python plugin: Domoticz SolarEdge_ModbusTCP
I might miss something, but battery still seems not to be recognized.
Stop, look and listen.
AddieJanssen
- Target OS: -
The output does not make sense - must be a few more bugs in the scanner. I will have a look into it tonight.
- JayDotR
Hi AddieJanssen,
I ran the scanner.py in a venv with pymodbus==3.15.0 as indicated in your https://github.com/addiejanssen/solared ... ec-scanner
Tried with solaredge_modbus 0.8.0 installed on top
(venv) pi@pihole:/srv/pymodbus-venv $ python -m pip list
Package Version
pip 26.2.1
pymodbus 3.15.0
pi@pihole:/srv/pymodbus-venv $ ./venv/bin/python3.13 ./scanner.py 192.168.1xx.xxx 1502 --device-id 3
Connecting to server
Connected to server
The inverter is providing a SunSpec Map
Reading Block at address [40002] for device [3]
Block id = 1: Common
Manufacturer: [SolarEdge ]
Model: [SE16K-RW000BNN4]
Options: []
Version: [0004.0025.0013]
Device Address: [3]
Reading Block at address [40069] for device [3]
Block id = 103: Inverter (Three Phase)
Reading Block at address [40121] for device [3]
Block id = 701: Unknown block
Closed connection to server
pi@pihole:/srv/pymodbus-venv $ ./venv/bin/python3.13 ./scanner.py 192.168.1xx.yyy 1502 --device-id 1
Connected to server
Reading Block at address [40002] for device [1]
Model: [SE6000H-RWS00BNO4]
Options: []
Version: [0004.0022.0044]
Device Address: [1]
Reading Block at address [40069] for device [1]
ERROR: request ask for id=1 but got id=3, Skipping.
Block id = 101: Inverter (Single Phase)
Reading Block at address [40121] for device [1]
Manufacturer: [SolarEdge]
Model: [SE-MTR-3Y-400V-A]
Options: [Export+Import]
Version: [79]
Device Address: [2]
Reading Block at address [40188] for device [1]
Block id = 203: wye-connect three phase (abcn) meter
Reading Block at address [40295] for device [1]
Package Version
pip 26.2.1
pymodbus 3.15.0
pyserial 3.5
pyserial-asyncio 0.6
solaredge-modbus 0.8.0
(venv) pi@pihole:/srv/pymodbus-venv $ ./venv/bin/python3.13 ./scanner.py 192.168.1xx.xxx 1502 --device-id 1
Connected to server
Options: []
Device Address: [1]
Version: [79]
Device Address: [2]
(venv) pi@pihole:/srv/pymodbus-venv $ ./venv/bin/python3.13 ./scanner.py 192.168.1xx.yyy 1502 --device-id 3
Connected to server
Options: []
Device Address: [3]
Domoticz Beta on raspberry3b, and raspberry4(b) on Rasbian Trixie / Python 3.13 / 64 bit
Using: PiHole, SolarEdge Modbus, Sainlogic / Weather Underground, MQTT, Fritzbox, P1 Meter(s), dzvents Scripting
https://www.github.com/janreimen/
AddieJanssen
- Target OS: -
Messages like "ERROR: request ask for id=1 but got id=3, Skipping." are most of the time caused by communication issues between the scanner and inverter. These can be time outs or when there are more than 2 connections to the inverter at the same time.
Running the scan multiple times may help, but may also show more errors...
The scanner is not using the solaredge_modbus library or anything of Domoticz. There's no need/benefit installing anything like that.
Even better: run the scanner in a clean environment where there's only the actual required components (which is pymodbus 3.15.0).
Last edited by AddieJanssen on Wednesday 23 September 2026 18:37, edited 2 times in total.
AddieJanssen
- Target OS: -
Thanks for running the scanner and sharing the outcome! It helps to figure out how these inverters actually return information.
I did some further reading based on the scans by imautohuttraeger and have found a more up to date list of Sunspec models.
This should reduce the number of "Unknown block" messages. It also became clear that these inverters can return a whole lot more information...
It took me some time to understand that the SolarEdge inverters don't return battery information conform the Sunspec battery model specifications.
SolarEdge has their own way of sharing battery information.
I have uploaded a newer version of the scanner that (hopefully) shows some battery information.
When there's no battery attached to the inverter, it may return all sorts of errors - sounds bad, but in fact is a good thing for my test.
So, would you be so kind to run the scans again with the new scanner and share the info here?
You can find the scanner at: https://github.com/addiejanssen/solared ... ec-scanner
Oh and one more thing: when the scanner is showing wrong, incomplete, or incorrect information, please share what the correct setup is.
Otherwise we have no clue what is missing or wrong.
Thanks all!
Thanks all!
- JayDotR
Hi Addie,
I will challenge my two foes (chatgpt and claude) : for my setup, I think I could send you both (python + results) in the late evening
hjzwiers
Hi Addie, are you building the controller according to the document:
Technical Note – Power Control Protocol for SolarEdge Inverters ?
- imautohuttraeger
I have replaced the file scanner.py by the new one (is that correct or do I need to do more?)
The result is an error:
When I delete the invalid character in line 161 ('·'), I get another error in line 7:
(scanner_env) pi@Raspberry:~ $ python /home/pi/solaredge-sunspec-scanner/scanner.py 192.168.1.143 1502
File "/home/pi/solaredge-sunspec-scanner/scanner.py", line 161
<title>solaredge-sunspec-scanner/scanner.py at main · addiejanssen/solaredge-sunspec-scanner</title>
SyntaxError: invalid character '·' (U+00B7)
File "/home/pi/solaredge-sunspec-scanner/scanner.py", line 7
<!DOCTYPE html>
SyntaxError: invalid syntax
- JayDotR
https://github.com/janreimen/Python-Ana ... -Registers
Nevertheless, I tried yours (cf. attached files)
- se6000h.txt
- Master Inverter
- (4.24 KiB) Downloaded 6 times
- se16k.txt
- Slave Inverter
- (3.63 KiB) Downloaded 6 times
AddieJanssen
- Target OS: -
That's not my scanner.py. That's an HTML page.imautohuttraeger wrote: Wednesday 23 September 2026 19:53 I have replaced the file scanner.py by the new one (is that correct or do I need to do more?)
When I delete the invalid character in line 161 ('·'), I get another error in line 7:Code: Select all
(scanner_env) pi@Raspberry:~ $ python /home/pi/solaredge-sunspec-scanner/scanner.py 192.168.1.143 1502 File "/home/pi/solaredge-sunspec-scanner/scanner.py", line 161 <title>solaredge-sunspec-scanner/scanner.py at main · addiejanssen/solaredge-sunspec-scanner</title> ^ SyntaxError: invalid character '·' (U+00B7) (scanner_env) pi@Raspberry:~
(scanner_env) pi@Raspberry:~ $ python /home/pi/solaredge-sunspec-scanner/scanner.py 192.168.1.143 1502 File "/home/pi/solaredge-sunspec-scanner/scanner.py", line 7 <!DOCTYPE html> ^ SyntaxError: invalid syntax (scanner_env) pi@Raspberry:~
Looks like you have downloaded the GitHub page itself....
Browse to https://github.com/addiejanssen/solared ... ec-scanner and just download the scanner.py.
AddieJanssen
- Target OS: -
Yes, but also some other docs of SolarEdge and Sunspec.hjzwiers wrote: Wednesday 23 September 2026 19:49 Hi Addie, are you building the controller according to the document:
When it comes to the inverter itself and meters attached to it, it's pretty nicely done by SolarEdge.
But when it comes to batteries... Ah well, I will make it work.
In a later stage I will look into the power control part of that document.
AddieJanssen
- Target OS: -
That looks pretty good!JayDotR wrote: Wednesday 23 September 2026 20:04 https://github.com/janreimen/Python-Ana ... -Registers
Does the output match the reality?
- imautohuttraeger
OMG - how embarrassingAddieJanssen wrote: Wednesday 23 September 2026 20:52 That's not my scanner.py. That's an HTML page.
Here we go:
Connected to server
Reading Block at address [40002 (0x9c42)] for device [1]
Block id = [1]
Block length = [65]
Block type = [Common - All SunSpec compliant devices must include this as the first model]
Model: [SE10K-RWB48BFN4]
Options: []
Version: [0004.0025.0011]
Serial Number: [hidden]
Device Address: [1]
Reading Block at address [40069 (0x9c85)] for device [1]
Block id = [103]
Block length = [50]
Block type = [Inverter (Three Phase) - Include this model for three phase inverter monitoring]
Reading Block at address [40121 (0x9cb9)] for device [1]
Block id = [1]
Block length = [65]
Model: [MTR-240-3PC1-D-A-MW]
Version: [1.0.62]
Device Address: [2]
Reading Block at address [40188 (0x9cfc)] for device [1]
Block id = [203]
Block length = [105]
Block type = [wye-connect three phase (abcn) meter]
Reading Block at address [40295 (0x9d67)] for device [1]
Block id = [701]
Block length = [153]
Block type = [DER AC Measurement - DER AC measurement model.]
Reading Block at address [40450 (0x9e02)] for device [1]
Block id = [702]
Block length = [50]
Block type = [DER Capacity - DER capacity model.]
Reading Block at address [40502 (0x9e36)] for device [1]
Block id = [703]
Block length = [17]
Block type = [Enter Service - Enter service model.]
Reading Block at address [40521 (0x9e49)] for device [1]
Block id = [704]
Block length = [65]
Block type = [DER AC Controls - DER AC controls model.]
Reading Block at address [40588 (0x9e8c)] for device [1]
Block id = [705]
Block length = [57]
Block type = [DER Volt-Var - DER Volt-Var model.]
Reading Block at address [40647 (0x9ec7)] for device [1]
Block id = [706]
Block length = [47]
Block type = [DER Volt-Watt - DER Volt-Watt model.]
Reading Block at address [40696 (0x9ef8)] for device [1]
Block id = [707]
Block type = [DER Trip LV - DER low voltage trip model.]
Reading Block at address [40803 (0x9f63)] for device [1]
Block id = [708]
Block type = [DER Trip HV - DER high voltage trip model.]
Reading Block at address [40910 (0x9fce)] for device [1]
Block id = [709]
Block length = [135]
Block type = [DER Trip LF - DER low frequency trip model.]
Reading Block at address [41047 (0xa057)] for device [1]
Block id = [710]
Block type = [DER Trip HF - DER high frequency trip model.]
Reading Block at address [41184 (0xa0e0)] for device [1]
Block id = [711]
Block length = [32]
Block type = [DER Frequency Droop - DER Frequency Droop model.]
Reading Block at address [41218 (0xa102)] for device [1]
Block id = [712]
Block length = [44]
Block type = [DER Watt-Var - DER Watt-Var model.]
Reading Block at address [41264 (0xa130)] for device [1]
Block id = [713]
Block length = [7]
Block type = [DER Storage Capacity - DER storage capacity.]
Reading Block at address [41273 (0xa139)] for device [1]
Block id = [-1]
Block length = [0]
Block type = [The End of the block list has been reached]
End of Sunspec MAP
Trying to probe for batteries
Reading Battery at address [57600 (0xe100)] for device [1]
Model: [SolarEdge Home Battery 48V - 3 ]
Firmware Version: [48V DCDC 3.5.13]
Serial Number: [7B0716D7]
Device id: [112]
Reserved: [0]
Next Address: [57666 (0xe142)]
Reading Battery at address [57856 (0xe200)] for device [1]
Model: [Home Battery 48V - 3 modules]
Firmware Version: []
Serial Number: []
Device id: [255]
Reserved: [0]
Next Address: [57922 (0xe242)]
Disconnected from server
hjzwiers
Ok, i will wait until you reach that stage, i am actively running the power control with a se10k-rwb48 with meters and 5 battery packs (23 kwh)AddieJanssen wrote: Wednesday 23 September 2026 20:55Yes, but also some other docs of SolarEdge and Sunspec.hjzwiers wrote: Wednesday 23 September 2026 19:49 Hi Addie, are you building the controller according to the document:
- JayDotR
Concerning my uploaded files :JayDotR wrote: Wednesday 23 September 2026 20:04 https://github.com/janreimen/Python-Ana ... -Registers
SE6000H is my Battery inverter (Mono-Phased 230V AC / 410 V DC)
SE-MTR-3Y-400V-A is the Meter used to define the working mode of the set of inverters (self-usage prior to sell if solar generation or battery available)
Battery is the right Device also
SE16K seems also legit read
for the specific registers, I will check during the weekend with my plugin if the readings I see are those read through pymodbus 3.5.8 + solaredge_modbus 0.8.0 and if they are in line with the output of your script
AddieJanssen
- Target OS: -
Would appreciate if you could run the scanner on your inverter. The more info the betterhjzwiers wrote: Thursday 24 September 2026 11:01Ok, i will wait until you reach that stage, i am actively running the power control with a se10k-rwb48 with meters and 5 battery packs (23 kwh)AddieJanssen wrote: Wednesday 23 September 2026 20:55Yes, but also some other docs of SolarEdge and Sunspec.hjzwiers wrote: Wednesday 23 September 2026 19:49 Hi Addie, are you building the controller according to the document:
- imautohuttraeger
BTW: No errors anymore with v2.0.7
AddieJanssen
- Target OS: -
Nice - thanks for the update
hjzwiers
I need the power and remote use to do what i do .... I'll wait until you have a working versionhjzwiers wrote: Thursday 24 September 2026 11:01Ok, i will wait until you reach that stage, i am actively running the power control with a se10k-rwb48 with meters and 5 battery packs (23 kwh)AddieJanssen wrote: Wednesday 23 September 2026 20:55Yes, but also some other docs of SolarEdge and Sunspec.hjzwiers wrote: Wednesday 23 September 2026 19:49 Hi Addie, are you building the controller according to the document:
hjzwiers
At what stage in the process are you?
I have dusted off and upgraded my development environment and found several topics that need attention:
There are outstanding pull requests on the master branch that address issues that multiple users encounter.
Key not found issues.
Incorrect values when inverter goes to sleep at night.
The detection of meters and batteries in the meters branch may not work for all inverters.
The meters branch requires the user to enter if they only have an inverter or if there are also batteries or meters attached. This is a result of a false response from the solaredge_modbus library for my own inverter.
The meters branch needs merging into master resulting in a release of version 2 of the plugin.
Upgrading from v1 to v2 will result in error messages as a result of changes in parameters. There's not a lot that can be done from a plugin perspective - needs to be documented as part of the upgrade instructions.
The solaredge_modbus library has been archived and needs attention.
The solaredge_modbus library does not verify the response of the inverter when reading batteries and meters. As a result, my plugin may "see" a non-existent battery or meter and collect random data from the inverter.
The solaredge_modbus library depends on another library: pymodbus. Since pymodbus has introduced changes in their API, the solaredge_modbus library will not work with the latests versions of pymodbus.
Domoticz has introduced a new plugin framework named "Extended Framework" and the framework used by my plugin is based on what is now named the "Legacy Framework".
Although there are no reported issues with my plugin using the Legacy Framework, it makes sense to migrate to the Extended Framework at some point.
