New Python plugin: Domoticz SolarEdge_ModbusTCP
imautohuttraeger
Domoticz version: latest
Re: New Python plugin: Domoticz SolarEdge_ModbusTCP
Post by imautohuttraeger »
I might miss something, but battery still seems not to be recognized.
Stop, look and listen.
AddieJanssen
Post by AddieJanssen »
The output does not make sense - must be a few more bugs in the scanner. I will have a look into it tonight.
JayDotR
Post by JayDotR »
Hi AddieJanssen,
I ran the scanner.py in a venv with pymodbus==3.15.0 as indicated in your https://github.com/addiejanssen/solared ... ec-scanner
(venv) pi@pihole:/srv/pymodbus-venv $ python -m pip list
Package  Version
pip      26.2.1
pymodbus 3.15.0
pi@pihole:/srv/pymodbus-venv $ ./venv/bin/python3.13 ./scanner.py 192.168.1xx.xxx 1502 --device-id 3
Connecting to server
 Connected to server
  The inverter is providing a SunSpec Map
   Reading Block at address [40002] for device [3]
    Block id = 1: Common
     Manufacturer:   [SolarEdge ]
     Model:          [SE16K-RW000BNN4]
     Options:        []
     Version:        [0004.0025.0013]
     Device Address: [3]
   Reading Block at address [40069] for device [3]
    Block id = 103: Inverter (Three Phase)
   Reading Block at address [40121] for device [3]
    Block id = 701: Unknown block
Closed connection to server
pi@pihole:/srv/pymodbus-venv $ ./venv/bin/python3.13 ./scanner.py 192.168.1xx.yyy 1502 --device-id 1
 Connected to server
   Reading Block at address [40002] for device [1]
     Model:          [SE6000H-RWS00BNO4]
     Options:        []
     Version:        [0004.0022.0044]
     Device Address: [1]
   Reading Block at address [40069] for device [1]
ERROR: request ask for id=1 but got id=3, Skipping.
    Block id = 101: Inverter (Single Phase)
   Reading Block at address [40121] for device [1]
     Manufacturer:   [SolarEdge]
     Model:          [SE-MTR-3Y-400V-A]
     Options:        [Export+Import]
     Version:        [79]
     Device Address: [2]
   Reading Block at address [40188] for device [1]
    Block id = 203: wye-connect three phase (abcn) meter
   Reading Block at address [40295] for device [1]
Tried with solaredge_modbus 0.8.0 installed on top
Package          Version
pip              26.2.1
pymodbus         3.15.0
pyserial         3.5
pyserial-asyncio 0.6
solaredge-modbus 0.8.0
(venv) pi@pihole:/srv/pymodbus-venv $ ./venv/bin/python3.13 ./scanner.py 192.168.1xx.xxx 1502 --device-id 1
 Connected to server
     Options:        []
     Device Address: [1]
     Version:        [79]
     Device Address: [2]
(venv) pi@pihole:/srv/pymodbus-venv $ ./venv/bin/python3.13 ./scanner.py 192.168.1xx.yyy 1502 --device-id 3
 Connected to server
     Options:        []
     Device Address: [3]
Domoticz Beta on raspberry3b, and raspberry4(b) on Rasbian Trixie / Python 3.13 / 64 bit
Using: PiHole, SolarEdge Modbus, Sainlogic / Weather Underground, MQTT, Fritzbox, P1 Meter(s), dzvents Scripting
https://www.github.com/janreimen/
AddieJanssen
Messages like "ERROR: request ask for id=1 but got id=3, Skipping." are most of the time caused by communication issues between the scanner and inverter. These can be time outs or when there are more than 2 connections to the inverter at the same time.
Running the scan multiple times may help, but may also show more errors...
The scanner is not using the solaredge_modbus library or anything of Domoticz. There's no need/benefit installing anything like that.
Even better: run the scanner in a clean environment where there's only the actual required components (which is pymodbus 3.15.0).
Last edited by AddieJanssen on Wednesday 23 September 2026 18:37, edited 2 times in total.
AddieJanssen
Thanks for running the scanner and sharing the outcome! It helps to figure out how these inverters actually return information.
I did some further reading based on the scans by imautohuttraeger and have found a more up to date list of Sunspec models.
This should reduce the number of "Unknown block" messages. It also became clear that these inverters can return a whole lot more information...
It took me some time to understand that the SolarEdge inverters don't return battery information conform the Sunspec battery model specifications.
SolarEdge has their own way of sharing battery information.
I have uploaded a newer version of the scanner that (hopefully) shows some battery information.
When there's no battery attached to the inverter, it may return all sorts of errors - sounds bad, but in fact is a good thing for my test.
So, would you be so kind to run the scans again with the new scanner and share the info here?
You can find the scanner at: https://github.com/addiejanssen/solared ... ec-scanner
Oh and one more thing: when the scanner is showing wrong, incomplete, or incorrect information, please share what the correct setup is.
Otherwise we have no clue what is missing or wrong.
Thanks all!
JayDotR
Post by JayDotR »
Hi Addie,
I will challenge my two foes (chatgpt and claude) : for my setup, I think I could send you both (python + results) in the late evening ;)
hjzwiers
Post by hjzwiers »
Hi Addie, are you building the controller according to the document:
Technical Note – Power Control Protocol for SolarEdge Inverters ?
imautohuttraeger
I have replaced the file scanner.py by the new one (is that correct or do I need to do more?)
The result is an error:
(scanner_env) pi@Raspberry:~ $ python /home/pi/solaredge-sunspec-scanner/scanner.py 192.168.1.143 1502
  File "/home/pi/solaredge-sunspec-scanner/scanner.py", line 161
    <title>solaredge-sunspec-scanner/scanner.py at main · addiejanssen/solaredge-sunspec-scanner</title>
SyntaxError: invalid character '·' (U+00B7)
When I delete the invalid character in line 161 ('·'), I get another error in line 7:
  File "/home/pi/solaredge-sunspec-scanner/scanner.py", line 7
    <!DOCTYPE html>
SyntaxError: invalid syntax
JayDotR
Post by JayDotR »
https://github.com/janreimen/Python-Ana ... -Registers ;)
Nevertheless, I tried yours (cf. attached files)
se6000h.txt
Master Inverter
(4.24 KiB) Downloaded 4 times
se16k.txt
Slave Inverter
(3.63 KiB) Downloaded 4 times
AddieJanssen
imautohuttraeger wrote: Wednesday 23 September 2026 19:53 I have replaced the file scanner.py by the new one (is that correct or do I need to do more?)
    <!DOCTYPE html>
That's not my scanner.py. That's an HTML page.
Looks like you have downloaded the GitHub page itself....
Browse to https://github.com/addiejanssen/solared ... ec-scanner and just download the scanner.py.
AddieJanssen
hjzwiers wrote: Wednesday 23 September 2026 19:49 Hi Addie, are you building the controller according to the document:
Yes, but also some other docs of SolarEdge and Sunspec.
When it comes to the inverter itself and meters attached to it, it's pretty nicely done by SolarEdge.
But when it comes to batteries... Ah well, I will make it work.
In a later stage I will look into the power control part of that document.
AddieJanssen
JayDotR wrote: Wednesday 23 September 2026 20:04 https://github.com/janreimen/Python-Ana ... -Registers ;)
That looks pretty good!
Does the output match the reality?
imautohuttraeger
AddieJanssen wrote: Wednesday 23 September 2026 20:52 That's not my scanner.py. That's an HTML page.
OMG - how embarrassing 🤦
Here we go:
 Connected to server
   Reading Block at address [40002 (0x9c42)] for device [1]
    Block id     = [1]
    Block length = [65]
    Block type   = [Common - All SunSpec compliant devices must include this as                                the first model]
     Model:          [SE10K-RWB48BFN4]
     Options:        []
     Version:        [0004.0025.0011]
     Serial Number:  [hidden]
     Device Address: [1]
   Reading Block at address [40069 (0x9c85)] for device [1]
    Block id     = [103]
    Block length = [50]
    Block type   = [Inverter (Three Phase) - Include this model for three phase                                inverter monitoring]
   Reading Block at address [40121 (0x9cb9)] for device [1]
    Block id     = [1]
    Block length = [65]
     Model:          [MTR-240-3PC1-D-A-MW]
     Version:        [1.0.62]
     Device Address: [2]
   Reading Block at address [40188 (0x9cfc)] for device [1]
    Block id     = [203]
    Block length = [105]
    Block type   = [wye-connect three phase (abcn) meter]
   Reading Block at address [40295 (0x9d67)] for device [1]
    Block id     = [701]
    Block length = [153]
    Block type   = [DER AC Measurement - DER AC measurement model.]
   Reading Block at address [40450 (0x9e02)] for device [1]
    Block id     = [702]
    Block length = [50]
    Block type   = [DER Capacity - DER capacity model.]
   Reading Block at address [40502 (0x9e36)] for device [1]
    Block id     = [703]
    Block length = [17]
    Block type   = [Enter Service - Enter service model.]
   Reading Block at address [40521 (0x9e49)] for device [1]
    Block id     = [704]
    Block length = [65]
    Block type   = [DER AC Controls - DER AC controls model.]
   Reading Block at address [40588 (0x9e8c)] for device [1]
    Block id     = [705]
    Block length = [57]
    Block type   = [DER Volt-Var - DER Volt-Var model.]
   Reading Block at address [40647 (0x9ec7)] for device [1]
    Block id     = [706]
    Block length = [47]
    Block type   = [DER Volt-Watt - DER Volt-Watt model.]
   Reading Block at address [40696 (0x9ef8)] for device [1]
    Block id     = [707]
    Block type   = [DER Trip LV - DER low voltage trip model.]
   Reading Block at address [40803 (0x9f63)] for device [1]
    Block id     = [708]
    Block type   = [DER Trip HV - DER high voltage trip model.]
   Reading Block at address [40910 (0x9fce)] for device [1]
    Block id     = [709]
    Block length = [135]
    Block type   = [DER Trip LF - DER low frequency trip model.]
   Reading Block at address [41047 (0xa057)] for device [1]
    Block id     = [710]
    Block type   = [DER Trip HF - DER high frequency trip model.]
   Reading Block at address [41184 (0xa0e0)] for device [1]
    Block id     = [711]
    Block length = [32]
    Block type   = [DER Frequency Droop - DER Frequency Droop model.]
   Reading Block at address [41218 (0xa102)] for device [1]
    Block id     = [712]
    Block length = [44]
    Block type   = [DER Watt-Var - DER Watt-Var model.]
   Reading Block at address [41264 (0xa130)] for device [1]
    Block id     = [713]
    Block length = [7]
    Block type   = [DER Storage Capacity - DER storage capacity.]
   Reading Block at address [41273 (0xa139)] for device [1]
    Block id     = [-1]
    Block length = [0]
    Block type   = [The End of the block list has been reached]
  End of Sunspec MAP
  Trying to probe for batteries
   Reading Battery at address [57600 (0xe100)] for device [1]
     Model:            [SolarEdge Home Battery 48V - 3 ]
     Firmware Version: [48V DCDC 3.5.13]
     Serial Number:    [7B0716D7]
     Device id:        [112]
     Reserved:         [0]
     Next Address:     [57666 (0xe142)]
   Reading Battery at address [57856 (0xe200)] for device [1]
     Model:            [Home Battery 48V - 3 modules]
     Firmware Version: []
     Serial Number:    []
     Device id:        [255]
     Reserved:         [0]
     Next Address:     [57922 (0xe242)]
Disconnected from server
hjzwiers
Post by hjzwiers »
AddieJanssen wrote: Wednesday 23 September 2026 20:55
Ok, i will wait until you reach that stage, i am actively running the power control with a se10k-rwb48 with meters and 5 battery packs (23 kwh)
JayDotR
Post by JayDotR »
Concerning my uploaded files :
SE6000H is my Battery inverter (Mono-Phased 230V AC / 410 V DC)
SE-MTR-3Y-400V-A is the Meter used to define the working mode of the set of inverters (self-usage prior to sell if solar generation or battery available)
Battery is the right Device also
SE16K seems also legit read
for the specific registers, I will check during the weekend with my plugin if the readings I see are those read through pymodbus 3.5.8 + solaredge_modbus 0.8.0 and if they are in line with the output of your script
AddieJanssen
hjzwiers wrote: Thursday 24 September 2026 11:01
Would appreciate if you could run the scanner on your inverter. The more info the better :)
imautohuttraeger
BTW: No errors anymore with v2.0.7
AddieJanssen
imautohuttraeger wrote: Thursday 24 September 2026 21:43 BTW: No errors anymore with v2.0.7
Nice - thanks for the update
