Hi Guys,
Does anyone know if there is a difference in the status of a switch if you switch it by hand(with regular switch) or switching it via a script or domoticz interface?
thnx!
switching a light by hand or sw Topic is solved
- waaren
Re: switching a light by hand or sw
Standard there is no difference.Trigun wrote: Friday 20 September 2019 14:55 Does anyone know if there is a difference in the status of a switch if you switch it by hand(with regular switch) or switching it via a script or domoticz interface?
If you change status by a script you can do some things to identify that the switch was triggered by the script,
Using a second (dummy) switch or a uservariable or by editing the description field of the switch and maybe by some other creative solutions.
Trigun
- Domoticz version: 4.10717
ok, cool! thnx for your reply.waaren wrote: Friday 20 September 2019 15:19Standard there is no difference.Trigun wrote: Friday 20 September 2019 14:55 Does anyone know if there is a difference in the status of a switch if you switch it by hand(with regular switch) or switching it via a script or domoticz interface?
working with a dummy might do the trick.
thnx!
